What do these collars do and do I need to replace mine.
LKNBigFish
Post by LKNBigFish »
I was cleaning my KIPS stuff with oven cleaner and did not realize these little collars were aluminum. The oven cleaner messed them up a little, but I am not sure if they are bad enough warrant replacing. Its an 01 KDX220. They have some imperfections but are still in pretty good shape, what does this part do and will it cause problems if they are not perfect?
The collars ar part 92143 on this diagram-- http://www.kawasakipartshouse.com/oempa ... d-cylinder
628627
Has thanked: 194 times
Been thanked: 49 times
Re: What do these collars do and do I need to replace mine.
Yeah, you got 'em. Just how coarse are they?
LKNBigFish
Jason wrote:Yeah, you got 'em. Just how coarse are they?
barely noticeable with your fingers, it looks worse than it feels
clean them up with some scotch brite, they should be fine. They are the bushings for the exhaust valves so as long as the valve's end doesn't bind in it you're good.
LKNBigFish
bufftester wrote:clean them up with some scotch brite, they should be fine. They are the bushings for the exhaust valves so as long as the valve's end doesn't bind in it you're good.
Thanks!
what he said
