Regular Maintenance?
sammydogjj
Post by sammydogjj »
What do you all do after your bike has been sitting for a couple months? I drained all the gas, motor oil, and spark arrestor goop. I also cleaned and rebuilt the carb. Anything else I should look at or clean/replace while I'm at it?
Tim
6 Riders
Re: Regular Maintenance?
Post by 6 Riders »
Grease the stem bearings, if you want to dive in real far, grease the linkage bearings.
sammydogjj
6 Riders wrote:Grease the stem bearings, if you want to dive in real far, grease the linkage bearings.
Thanks!
Tim
pumpguy
Post by pumpguy »
Wheel bearings and brake pads are also frequently neglected.
sammydogjj
pumpguy wrote:Wheel bearings and brake pads are also frequently neglected.
I replaced those right before I stowed it for the season. Thanks, though!
Tim
K50X200
Post by K50X200 »
After my KDX sits for a couple months I usually roll it out of the garage, turn on the fuel, kick it over once - maybe twice, and go for a ride... :grin:
A couple years would probably be a different procedure involving grease, bearings and brake pads, etc...
"00 KDX200 - Baja Designs D/S Kit, '03 KLX300 Forks, KB5 Suspension Mods, Keihn 35 ASQV, Boyesen Rad Valve, Gnarly Woods Pipe
sammydogjj
K50X200 wrote:After my KDX sits for a couple months I usually roll it out of the garage, turn on the fuel, kick it over once - maybe twice, and go for a ride... :grin:
Yep! I've already ridden it once or twice after it sat for the winter. Overflow issue :(, so I'm still rebuilding the carb and adjusting floats. Hopefully that fixes it and that's the only issue I am aware of.
Tim
