Hello guy's,
I have a problem with my kdx200 Kips lever shaft. This is the little plate attached to the lever with a nut. Now my problem is that when you turn the plate the lever sometimes doesn't turn with it. But the nut is locked ( i can't even get it loose ). Now is this suppose the be like this or should it be locked? And if it have to be locked in what position? In 90° angle to the little plate in the bottom attached with allen bolts?
I would upload a video of the problem but I don't know how.
If you have questions about my problem just ask.
Thanks in advance.
KIPS lever shaft
Sander34
bultaco4ever
Sander34
Re: KIPS lever shaft
Jep. But it is locked and the plate isnt tight. So this isnt normal? What position should i lock it?
bultaco4ever
KIPS lever shaft
So, you have the governor shaft and the governor lever and a LH nut that goes on top of the shaft. You don't have it upside down, do you? I use a big adjustable crescent wrench to support the lever when I tighten the nut that holds it to the shaft....counter clockwise to tighten....use Loctite (blue).
- Tedh98
I am not familiar with the E series, but I would assume there is a pin or some other type of system that would mechanically connect the rod and lever together. The LH nut just keeps them together.
Sander34
I don't understand.
you got a lever ( cilinder ) on the bottem end off the cilinder you got the litte plate with the allen bolts and on the top of the lever you got thread. Over this thread sits a little plate and to hold it together there is this bolt ( LH ) but the plate on the top end moves in my case. even if the bolt is tightend. And i could lock it with a weld beam or something but then i need to know in what position the plate has to be.
Is there a way i can upload images or a video so i can make clear to you guy's what i mean?
kind regards
kind regards
- Tedh98
The LH nut shouldnt be the only thing that holds those two parts together. On the H series a pin mechanically holds them together AND positions the lever properly.
I am guessing something is broken or missing on yours. But pictures would be helpful.
