Changing front forks to KX250f front forks
Roman220
Hey I have a 2003 KDX220R and I want to swap the front forks out to a 2004 KX250F front ones. I know I will need the lower tree triple clamp but im not sure ill need anything else.
- doctord23
Re: Changing front forks to KX250f front forks
Upper and lower clamps for the KXF plus swap out the stem plus a spacer / shim from Ron Black.
That will do it. You can make your own spacer and shim, but buying one is easier and cleaner.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
- 6 Riders
You'll need the kx front wheel as well. Brakes should swap over, everything else needs to ne changed. You also need to modify the steering stops.
Pipeliner
- Has thanked: 190 times
Make your own or check with Ron Black. RB Designs
