95 kdx200 won't start!
cooksto1
Post by cooksto1 »
I got a 95 kdx200 on a trade, ran great when i test drove it and ran great the next day. I dumped it and the clutch cable frayed so I parked it and waited for a new one. Replaced the cable and went to start her up and nothing. I checked the ignition coil and it was junk so i ordered a new one, just put it on and still won't start. Any help would be useful
royadams
Re: 95 kdx200 won't start!
Post by royadams »
Is it getting any spark. I would clean and check all grounds. And unhook kill switch.
cooksto1
Post by cooksto1 »
It's got spark and I've unhooked the killswitch. Really has me stumped
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
Tedh98
Been thanked: 2 times
Post by Tedh98 »
cooksto1 wrote:I got a 95 kdx200 on a trade, ran great when i test drove it and ran great the next day. I dumped it and the clutch cable frayed so I parked it and waited for a new one.
Did you start it after dumping it or did you just push it back?
cooksto1
Post by cooksto1 »
Started it and rode until I noticed the frayed cable, maybe 5 minutes. I didn't even dump it hard, i was just putting around
ohgood
Post by ohgood »
cooksto1 wrote:It's got spark and I've unhooked the killswitch. Really has me stumped
compression test = you want 140psi or greater
fuel test = you want a smooth flow through the carb if/when you lean the bike over
spark test = you want a FAT BLUE spark
timing test = make sure the flywheel key (on the shaft) is not sheared. if it were, you would still get a nice spark, but the timing would be off, and it may not run at all. this is unlikely, but possible. i would be on fueling or bad plug wire. both easily fixed.
cooksto1
Post by cooksto1 »
What could be the likely cause of weak spark? Replaced the ignition coil and I'm not really sure what else it could be other than a bad stator
Jaguar
Country: Ecuador
Post by Jaguar »
any spark is enough to start it.
it was running and you dumped it. probably flooded. maybe even have gas in the crankcase.
