7/8 bars
dualscotty
7/8 bars
Post by dualscotty »
Replacing my bars. Staying with the 7/8 size so my bark buster hand guards will still fit. Looking at renthal Ricky charmicheal bend any body ever bought these. Thanks
diymirage
Re: 7/8 bars
Post by diymirage »
a flaw in your logic: the thicker bars are only thicker in the center, and then taper back out
your bark busters should fit fine, though you may need to machine the inner posts 1/8th of an inch
as for the bend, I honoustly cant remember what I run
-1997 KDX 220 project bike
6 Riders
Re: 7/8 bars
Post by 6 Riders »
I run Pro Taper (I recommend over Renthal) Windham and Carmichael bends. I like the Carmichael's if using a riser/adapter, the Windham's w/o.
Re: 7/8 bars
diymirage wrote:a flaw in your logic: the thicker bars are only thicker in the center, and then taper back out
Come on, now. They wouldn't be a straight bolt on and some mounts can't be opened up without weakening them too much. Plus, he might not own the right tools to open up the mounts properly. There is nothing wrong with 7/8" bars and they are way cheaper. Just make sure you do have the metal wraparound bark busters on them or they will bend the first time you crash like most 7/8" bars. The only plus, IMO, with the 1-1/8" bars is that you can ditch the crossbar. BTW, I just bent a set of 1-1/8" bars at the last race. They aren't that superior. Just sayin!
As for bar bends, I like the CR High bend. Brand doesn't really matter a whole lot to me. I've run the cheap Tusk with no problems.
dualscotty
Re: 7/8 bars
I do run wrap around barkbusters. 7/8 bars have seemed to always work fine for me too. I currently have 1 inch risers. What bend is good for not using risers. I'm 6' 2". Thanks
dualscotty
Re: 7/8 bars
Tusk bars xr high end. Comparable to windam bend? Thanks for the input
diymirage
Re: 7/8 bars
Post by diymirage »
I never questioned the quality of the 7/8th bars
the way the original post was written, it sounded like the ONLY reason he wanted to stay with the 7/8th bars instead of moving up to 1 1/8th was the bark busters...and that was the only point I addressed
shoe757
Re: 7/8 bars
Post by shoe757 »
I don't know I've personally bent every pair of 7/8 bars on anything I've owned. Never bent renthal fat bars, though I did trash a lonestar steering stem without even tweaking the bars. But some people prefer 7/8. I run windham bend (highest fat bar I believe) and I have about an inch riser RC is pretty close too. I'm 6'4" and like them high. I wouldn't personally run cheap bars if I could afford a better brand. I know motosport had Mika 7/8 on sale.
02 Kdx220
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
dualscotty
Re: 7/8 bars
I assumed that where the bark buster bracket bolts to the low part of the bar wouldn't fit fat bars. And a new bracket would be involved also new bar ends for fat bars also. Figured I'd keep it simple and stick with 7/8 but with all your input I think I'll convert to fattys. I see tusk adapter/ risers for converting. Is this a good way to go or should I get proper mounts that take place of the old mounts on the stem
6 Riders
Re: 7/8 bars
Post by 6 Riders »
dualscotty wrote:I assumed that where the bark buster bracket bolts to the low part of the bar wouldn't fit fat bars. And a new bracket would be involved also new bar ends for fat bars also. Figured I'd keep it simple and stick with 7/8 but with all your input I think I'll convert to fattys. I see tusk adapter/ risers for converting. Is this a good way to go or should I get proper mounts that take place of the old mounts on the stem
Either way is fine. You might want to adjust the bar bend depending on which bar mount you go with. I love my fat bars, can't go wrong with them.
diymirage
Re: 7/8 bars
Post by diymirage »
arguably, the mounts that bolt into the triple and replace the mounts you have now would be best
(which also allows you to get rid of the cones some people don't like)
I just went with a set of these
http://www.ebay.com/itm/28MM-1-1-8-Hand ... VN&vxp=mtr
the bolt in place of the 7/8 handle bars and act as risers
then the 1 1/8th bars bolt into those
this has worked fine for me for years
as far as the lower mounts for your bark busters
I took mine off and bolted them together again (like they would be tightly clamped on the bars
then I placed the whole unit In a vice and ran a 1 inch drill bit through it
(this does take about 1/16th of material out both sides of the mount but I wasn't too bothered by that, they have held up great for years
of course, if you are worried they wouldn't hold up, they do sell those mounts for the 1 1/8th bars
shoe757
Re: 7/8 bars
Post by shoe757 »
You won't need new bar ends unless you mess one up trying to get it out. Fat bars are awesome, especially on two strokes, lot less felt vibration through the bars. I've put 7/8 busters on 1 1/8 bars before but like ss109 said they won't be perfect. Never had a problem though. 1 1/8 bars are only that day where they mount to your bar clamps and taper down to 7/8 where the grips are. I went with turner adapters off of motosport for around $30 they are VERY solid and well built. Plus you get a nice inch of rise from them. I'd recommend those mounts with RC High bend Fat bars if you have the cash. Good luck!
02 Kdx220
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
Re: 7/8 bars
diymirage wrote:I never questioned the quality of the 7/8th bars
My apologies. I know you weren't. I was just adding it to my post and it wasn't directed to you.
shoe757 wrote:I don't know I've personally bent every pair of 7/8 bars on anything I've owned. Never bent renthal fat bars...
That's funny because the 1-1/8" bars I bent were Renthal Fat Bars! Even with Enduro Engineering wraparounds on I bent them! :mrgreen:
shoe757
Re: 7/8 bars
Post by shoe757 »
That's funny because the 1-1/8" bars I bent were Renthal Fat Bars! Even with Enduro Engineering wraparounds on I bent them! :mrgreen:[/quote]
You really need to stop letting semi trucks run that beautiful bike over! :boogie:
02 Kdx220
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
chippy
7/8 bars - origional question
Post by chippy »
dualscotty wrote:Replacing my bars. Staying with the 7/8 size so my bark buster hand guards will still fit. Looking at renthal Ricky charmicheal bend any body ever bought these. Thanks
Yes.
These are my "go to" bars on all of my bikes. Renthal 721 bend. They are excellent. They fit well and are nearly impossible to bend! I prefer them to any of the fat bars.
dualscotty
Re: 7/8 bars
Thanks for the input I'll check them out
chippy
7/8 bars
Post by chippy »
You're welcome.
BTW - I also run the 1" risers on my bikes. It make for a perfect fit for me! ( I do stand up a lot though)
dualscotty
Re: 7/8 bars
Any pics of them chippy
chippy
Re: 7/8 bars
Post by chippy »
I will try to take some tomorrow. They do look good! ;^)
These bars came stock on my Honda CRF250x and I liked them well enough to put them on my other bikes. I like to run the Renthal full diamond grips in hard or medium compound. My favorites for sure.
dualscotty
Re: 7/8 bars
Thanks look forward to some pics
