Bottom End
1Kam
Bottom End
Hey my Name Is Kam & I have an 02 KDX 200 and I'm trying to rebuild my bottom end but I can't find the Kit for it , does anyone know where I can Find one ?
- Tedh98
- Been thanked: 2 times
Re: Bottom End
There is no "kit" for the kdx. You need to buy everything individually and get your or another OEM crank rebuilt.
You can buy the seals and or gaskets as a complete set, but they wont be OEM.
1Kam
david
- Country: UNITED STATES
Re: Bottom End
You get 3 seperate 'kits'. Then like Ted said, take the rod kit and your crank to a motorcycle machine shop to have them build your crank. Then you reassemble everything else. You may or may not have to have your cylinder replated depending on the condition of it. If you need crank bearings, those are separate. You can get them from Kawasaki or go to your local bearing supply house and get some NTN or SKF replacements (6305JR2C3).
Connecting rod kit
Piston & ring kit
Gasket & seal kit
Connecting rod kit
Piston & ring kit
Gasket & seal kit
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
1Kam
sarrant
Re: Bottom End
Concrete looking oil: You mean, transmission oil?
Because the bottom end is oiled by premix fuel.
1Kam
Re: Bottom End
lol I guess This is My First KDX & someone said It Might Be my Bottom end But I believe my Pistons are Seized
pumpguy
Bottom End
Could be lots of problems.
An easy way to see if problem is bottom end is to see if the crankshaft will rotate.
One way to do this is to remove the flywheel cover and spark plug. Then put the transmission in neutral and try to rotate the flywheel by hand or with a wrench.
If you can't rotate the flywheel, then you most likely have a seized piston, or less likely bad big end or main bearings.
Good luck and let us know what you find.
sarrant
- Tedh98
Re: Bottom End
1Kam - I think it would be helpful to provide some more background on what is happening with your KDX.
1Kam
Re: Bottom End
It was running good , until I cut it off and let it sit for an hour and once I tried to start it back up the Kicklever moved twice then after that I wouldn't move anymore
sarrant
Bottom End
Well, there may be a couple of things going on here.
If you've never taken the top end off, now's probably the time. Even if the problem is not in the engine (it is in that cementy-looking transmission case), now would be a good time to inspect the top end and see if it needs refreshing. Once you have the top end off, you'll be able to identify where the problem is if in the engine (top or bottom).
As for the oil that looks like cement: Is it watery/frothy, or is there a lot of metal in it?
If it is watery, your water pump seal has probably gone, and perhaps there was an overheating issue that lead to seizure. If it is metallic, perhaps something has broken loose in the cases and that is what is locking the kickstarter.
There is more than one possibility here, and you are going to need to investigate further before you have enough info to identify the problem.
1Kam
