No power in 1st gear
Scrandy
Hey so I picked up my 2004 kdx 220 and had it out for 3 rides so far. What i've been noticing on the 2nd and 3rd ride is when i go wide open in first gear it almost sounds like it has a misfire and won't rev up all the way but when I have it under load like going slow for second gear and crack the throttle it goes just normal, either rips a massive rut in the grass or dirt or pulls a wheelie.
2004 KDX220R. I'm Canadian eh.
Scrandy
Oh yeah I forgot to mention, it's always started first kick when it's warm and first or second when cold. So today I stopped and shut off my bike for about 5 minutes. It took 4 kicks to start, the first 3 it did not sound like it wanted to start what so ever. Then the forth kick it started right up like normal. Any thoughts on what this could be??
rparrish08
Re: No power in 1st gear
Make sure the KIPS is working. If the valve is stuck open then you will have limited power below about 6k rpm's.
I have fought the good fight, I have finished the race, I have kept the faith. 2 Timothy 4:7
- Jaguar
- Country: Ecuador
- Been thanked: 2 times
weak with little engine load, and strong under load means it is jetted too rich.
lean out the main jet, drop the needle 1 or 2 notches and adjust the idle air screw correctly.
