How to get flywheel off?
mwoj
Post by mwoj »
So I just took the clyinder off my 85 kdx 200. I am about to take off flywheel but I can across and issue.
I bought a flywheel puller off of eBay for $9 shipped. It's has larger threads and then a smaller bolt that goes agains the crankshaft. However, there is nothing for the larger thread to go into. How am I supposed to get the flywheel off? I took off the center bolt that holds it on but it's not sliding off ( because I need to use a puller) yet the puller doesn't fit. I don't see how any puller could fit. What do I use?
royadams
Re: How to get flywheel off?
Post by royadams »
Never seen a flywheel without a threaded center. It's a lefthand thread. Are you sure the threads are not just a little rusty. How about a pic.
mwoj
Post by mwoj »
mwoj
Post by mwoj »
Been thanked: 19 times
The older bikes didn't have a threaded centre. Use a puller screwed into those two threaded holes in the front of the flywheel.
Been thanked: 57 times
There should be three threaded holes on that flywheel. Use a puller similar to below to get it off.
Has thanked: 194 times
Been thanked: 49 times
