spoogy 95 200....frustrated
argclh6670
Post by argclh6670 »
ill try posting this here...my kids 95200 spooges big time! it has lean pilot...it still loads up badly...main seems good....running jd needle (leaner of the two)on #1....runs great when on the pipe....changed jetblock gasket...floats set numerous times...didcthe water test to see if inlet needle was leaking...passed. not sure what else it could be?? any suggestions?
Tedh98
Re: spoogy 95 200....frustrated
Post by Tedh98 »
Leaking crank seal?
james
Post by james »
Tedh98 wrote:Leaking crank seal?
which seal?? part no?? 92049/50/51???
YOU CAN MASSAGE THE THANKS BUTTON THANKS!!!!
Tedh98
Post by Tedh98 »
92049
Jaguar
Country: Ecuador
Post by Jaguar »
synthetic or semi-synthetic oil leaves less spooge
argclh6670
running semi syn....did leakdown test, after laat topend....passed. the spooge prob has been around since we got the thing... the bike just drinks rhe fuel too....in a ahort course HS it isnt uncomnon for the son to switch to reserve on last loop.
ohgood
Post by ohgood »
argclh6670 wrote:running semi syn....did leakdown test, after laat topend....passed. the spooge prob has been around since we got the thing... the bike just drinks rhe fuel too....in a ahort course HS it isnt uncomnon for the son to switch to reserve on last loop.
there is a gasket (and oring) under the jet block in the carb. it's a common failure point.
Tedh98
Post by Tedh98 »
It is the stock carb, correct? What is your elevation and what size main jet?
To be running a 38 pilot and the clip at the first position is awfully lean (unless you ride in high elevations) for the 200. Seems like a lot of extra gas is getting to the engine.
Does gas run out the overflow if you lean the bike at a slight angle?
Do you have any way to swap carbs?
Any chance the jet block gasket shifted out of place when you replaced it?
argclh6670
yeah...stock carb. 155 mj. no fuel leaks out unless of course its all the way over on its side. i wish i had another carb to swap in for testing.
Tedh98
Post by Tedh98 »
Do you have any non-JD needles to try? I was thinking that maybe the JD needle you are using isn't meant for the KDX. Going back to the stock needle or one of the more common alternatives could shed some light.
argclh6670
i have the stock needle, cel and del....the jd kit is was for the kdx....the kit eorked great for my RMX so i picked pne up for kdx too.
Tedh98 wrote:Do you have any non-JD needles to try? I was thinking that maybe the JD needle you are using isn't meant for the KDX. Going back to the stock needle or one of the more common alternatives could shed some light.
Tedh98
Post by Tedh98 »
So does it do run poorly and use that much fuel with those other needles?
The JD needles could have been mis-labeled.
I used JD needles years ago on my 200 and was extremely happy with them.
argclh6670
yes it does, even worse. starting to wonder if needle jet seat is worn?
Tedh98
Post by Tedh98 »
Other than something internally worn or damaged in the carb, the only other thing I can think of is reeds. Were they in good shape when you did the engine work?
Jaguar
Country: Ecuador
Post by Jaguar »
the float valve could be letting gasoline past it when it should be closed (due to the float being high enough).
also if the float itself is leaky then it won't be bouyant enough and will let the gas level rise.
