New rear brake pads toast after 1 ride....why?
argclh6670
Post by argclh6670 »
Hey people....i put brand new set of (cheaper) pads on rear of sons hybrid kdx/kx250 ...raced a very muddy and wet HS today. As i was loading up i noticed tat the pads were completely worn to to the backing plate. Has anybody else had pads wear this quickly? I realize that heavy sediment on rotor would assumingly act as sandpaper....but sheesh.
Has thanked: 27 times
Been thanked: 31 times
Probably a combination of the mud along with dragging the rear brake. However, check to make sure the brake return spring is working.
Bitteeinit
Re: New rear brake pads toast after 1 ride....why?
Post by Bitteeinit »
If you love in an area where the mud is sandy then yes, quite possible.
Sent from my ASUS_Z00AD using Tapatalk
tmmyghst
Post by tmmyghst »
Solid rotor for very muddy conditions.
Tyl3r
Post by Tyl3r »
I was going thru rear pads like crazy on my quad and couldn't figure out. I believe my problem were the pins that the calipers rode on. Both of them had some small grooves in them. One day I decided to change the pins when I changed the pads. I haven't had to change my rear pads since. I figure the pads were getting hung up on those grooves and not allowing the pad to move as freely as it would like. That could be something to check.
6 Riders
Post by 6 Riders »
We are having the same problem at Straddleline. I put a set of gapher's on my bike and a set of EBC on my son's bike for Sundays race. I'll get a look at the pads tonight.
6 Riders
Post by 6 Riders »
Just went and looked at the brakes.....They are toast. The brake pins are new, so I'm gathreing that it's that thick clay/mud and a LOT of rear braking that is eating them up.....I guess I'm going back to the cheap ones until the series is over.
argclh6670
Crazy how fast they wear!! Good thing i stock up on the cheap ones...lol. You were riding great this weekend....definitely see improvement in your son too!
6 Riders wrote:Just went and looked at the brakes.....They are toast. The brake pins are new, so I'm gathreing that it's that thick clay/mud and a LOT of rear braking that is eating them up.....I guess I'm going back to the cheap ones until the series is over.
6 Riders
Post by 6 Riders »
argclh6670 wrote:Crazy how fast they wear!! Good thing i stock up on the cheap ones...lol. You were riding great this weekend....definitely see improvement in your son too!
Thanks, Riding has/had been hard for me lately, but I go for my boys. 95 is done, so I should have it at the last race :supz:
cornishwrecker220
Post by cornishwrecker220 »
Wet,muddy conditions will wear pads .....a solid rear rotor will reduce wear on the pads but also help with braking & longevity, there are a lot of pads out there to choose from & at various prices too, it's always best to fit quality brake pads that are specific for your requirements....I always buy pads marked for MX or Enduro ....EBC ( red pads ) or Brembo are excellent albeit not the cheapest..... But hey you gets what you pay for......also be careful when buying frOm EBay as some items have found to be counterfeit !
Has thanked: 116 times
What kind of rotor and what kind of pads, also what style, semi-mettalic, organic, etc.?
cornishwrecker220
Vented discs, & wavy discs are to reduce heat build up , but with vented discs mud & grit can & will block the holes & cause the pads to wear faster . stintered pads ( pads with metal in with the ceramic material ) work very well but at a cost.....they wear the discs quicker than normal.
Any off road motorcycle will wear discs & pads ....a disc guard can help reduce premature wear by deflecting mud & crud off & away from the disc & brake calipers .
