1991 kdx 250 help
Discussion specific to the 1991 - 1994 KDX250 sold in the USA
adamryan30
1991 kdx 250 help
Post by adamryan30 »
Hey guys just joined the forum and new to owning a kdx. Just got a 1991 kdx 250 from a neighbor for free as it's been sitting in garage for a while so obviously carb needs to be cleaned. But I checked the compression and getting a reading of only 90 psi. Seems very low. Questions is compression that low, would it keep a bike from starting?
KDXohio
Re: 1991 kdx 250 help
Post by KDXohio »
Could still run...not well.
Definitely in need of a rebuild!
adamryan30
That's what I was figuring...should I just redo the top end or you think bottom should be rebuilt as well? Also completely off topic but what size gas tank do these have and what kinda mileage are people getting out if a tank?
radonc73
Post by radonc73 »
I would just do the top end. The bottom end should be good. Mileage has never been an issue for me. If you fill the tank you will have plenty of gas for an entire day of riding IMO.
Riding is living everything else, is just waiting.
Master of the casual pace
83 KDX 200
93 KDX 250
84 YTM 225 DX 3-WHEELER
No way to accurately diagnose it over the internet.
Does it not crank at all? There are several things to check if so.
1991 kdx 250 help
Do a leak down test to see if the crank seals are good. They can go bad from just sitting for long time.
My brain needs a leak down test. This thread was 5 months old when radonc replied. :wink:
