Kips lubricant
waldo177
Kips lubricant
Post by waldo177 »
Just a quick question, what is the best high temp grease to use to lubricate the kips components? White lithium grease?
Sent from my SM-S920L using Tapatalk
Jim B
Re: Kips lubricant
Post by Jim B »
Premix/2-stroke oil.
waldo177
Re: Kips lubricant
Post by waldo177 »
Can you elaborate?
waldo177
Re: Kips lubricant
Post by waldo177 »
I'm in the process of rebuilding my top end and the manual says to lubricate the o ring on the valve shafts with high temp grease and I'm trying to figure out what to use
JFortner5
Re: Kips lubricant
Post by JFortner5 »
waldo177 wrote:Can you elaborate?
Whatever oil you use to mix with your gas. I always just pour some in the cap and dip my finger in it and coat the KIPS parts during reassembly.
Jim B
Re: Kips lubricant
Post by Jim B »
Well, I suppose you could use high temp grease, since that's what the manual says. I figure premix/2-stroke oil is what's going to lubricate the parts while you operate the bike, so why not use it for assembly? I'd imagine either way should be okay.
Tyl3r
Re: Kips lubricant
Post by Tyl3r »
Someone posted this link in another thread recently and I was reading it last night.
http://www.thumpertalk.com/topic/657765 ... to-kdx200/
He used pre-mix oil to lube all the KIPS parts during assembly. Seems like the best way to go to me. If you used hi temp grease on those parts, wouldn't the pre-mix oil mix in with the grease while the motor is running? Just seems odd to me, I must be missing something.
6 Riders
Re: Kips lubricant
Post by 6 Riders »
I soaked my kips parts in 2-T oil before assembly, overnight IIRC.....Couldn't think of anything better to use.
JFortner5
Re: Kips lubricant
Post by JFortner5 »
I think getting the parts cleaned good is more important than what oil is on it. As long as it moves freely it should be fine.
Sullyfam
Kips lubricant
Post by Sullyfam »
If I read your 2nd post (#4) correctly, you are asking what to put on the O ring versus the other kips components. As others have said,premix oil on the parts and o ring works just fine. However, if you want to follow the manual then any auto parts store will have high temp grease you can use for just the o ring.
