96 kdx premix instead of oil pump
joncf1997
I have a 1996 Kawasaki kdx 200 I was wondering if I can just pre mix instead of using the oil pump or if that would hurt something in the motor. Any suggestions will be helpful.
Sent from my SCH-S968C using Tapatalk
jjavaman
Re: 96 kdx premix instead of oil pump
I never knew kdx's had pumps??? If yours does, it should be fine to block it off and use pre mix. Where are you from?
koshari
My old SR had a pump. Just make up a plate to go over the pump hole and itilise the 2 screws that mounted it. You will also need to block the tube on the reed cover.
joncf1997
joncf1997
joncf1997
joncf1997
- diymirage
any chance you can post a few close up pictures of the oil pump ?
ive never seen an SR model up close, and all of my KDXs just run premix
-1997 KDX 220 project bike
sarrant
That's not an SR. That's an H-Series.
There is no oil pump. Premix only.
Are you by chance putting oil in the coolant overflow tank? It does look like a Yamaha oil injection tank.
joncf1997
joncf1997
joncf1997
Here's a picture of my old 1996
koshari
Sarrent is correct. You have a periphial framed bike. The SR was based on the earlier models. I suspect you are indeed speaking of the coolant reservoir.
- Has thanked: 194 times
- Been thanked: 51 times
Please tell us that you did not run the engine on straight gasoline.
That little tank is for the coolant reservoir.
- Tedh98
- Been thanked: 2 times
Or in this case it could be a water pump seal lubricator.Jason wrote:That little tank is for the coolant reservoir.
joncf1997
No I didn't even crank it. Thanks for the info.
joncf1997
I was just wondering what it was before i mest something up.
FREE download of the 1996 KDX200 owner's manual from the Kawasaki website:
http://www.kawasaki-techinfo.net/showOM ... ng_code=EN
- diymirage
joncf1997 wrote:I was just wondering what it was before i mest something up.
like pointed out by now, what you are looking at in in fact the radiator overflow reservoir
if your mechanically inclined, just pull that shroud of and have a good look at it
the way the lines hook up to the radiator are a dead give away....as is the writing on the cap
still, points for asking what is what before assuming and wrecking a good bike
