I have an '01 KDX200 with an FMF Gnarly pipe and an FMF Turbine Core 2 silencer.
I'm doing my first silencer repack and have a couple questions.
When I pulled out the old packing today, it was totally saturated with oil spooge.
I also noticed that the silencer was wrapped with a layer of steel wool, followed by some kind of screen (sort of like window screen)
Then on top of that was the fiberglass packing.
Do I need to keep that steel wool, and screen or can I just use the fiber glass only?
If I do need the steel wool, should I replace it, since it's pretty saturated too?
The last question is I noticed that the lower allen screw that holds the can to the pipe was a little loose, I tried to tighten it, but it won't fully tighten. It this okay? Should I put a little silicon or thread locker on it?
Thanks again for helping with this. It seems everything I do on this bike has me baffled at some point.
more silencer re-packing questions
bws2
- ss109
- Has thanked: 30 times
There should be no steel wool or screen inside a Turbine Core silencer. It should only have standard 2T silencer packing material.
Does it look like the following pic from the outlet?
And not like this?
As for the screw, put some high temp silicone on it and it should be fine.
And not like this?
bws2
Re: more silencer re-packing questions
Thanks SS.
Just to clarify, the steel wool and screen extended the entire length of the perforated pipe (10-12 inches) and then had fiberglass packing on top.
It didn't look factory since both the steel wood and screen were cut crooked in places.
I'm having problems figuring out which picture it looks more like, since the end of the muffler (spark arrestor?) is riveted on and I wasn't able to remove it. Is there something else I should be checking?
Also, I have 4 stroke FMF packing, is it okay to use that on my bike?
MarioM3
I just packed my powercore, same design (riveted on exhaust end). I used 2 stroke packing, you can use 4 stroke but I think you may have to change 4 stroke packing more often when used. But I do believe the steel wool/screen material is not stock. Just make sure you clean the perforated pipe as best as you can (all holes should be open). I used a wire brush with parts cleaner, worked well. When reinstalling use some good high temp silicone.
Mario
Mario
bws2
Thank you, Mario. One thing that surprised me is how good the perforated pipe looked. No holes were plugged. Maybe the steel wool had something to do with that.MarioM3 wrote:I just packed my powercore, same design (riveted on exhaust end). I used 2 stroke packing, you can use 4 stroke but I think you may have to change 4 stroke packing more often when used. But I do believe the steel wool/screen material is not stock. Just make sure you clean the perforated pipe as best as you can (all holes should be open). I used a wire brush with parts cleaner, worked well. When reinstalling use some good high temp silicone.
Mario
