Differences between 89 and 94 E series?
Ffryno13
I'm looking for a donor for my kdx/mx swap and I was wondering if there's a difference between the 89 and 94 Most of the bikes I've found are around 2k and thats a little out of the budget for what I'm doing.
david
- Country: UNITED STATES
Re: Differences between 89 and 94 E series?
I think the '89 has a different KIPS valve design. I know that it has a different water pump seal. I believe that's about it. You know, first year bugs being ironed out.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
- kx200
The 89 KIPS are the same but for some reason the head has a different part #11001-1291 vs 11001-1317
david
What I found is: '89-'91 have a different main exhaust valve from the '92-'94.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
frenche200
on the e série there were two différents type on center valvewith a specific wave wacher for thé first model, but swap is all right. Fork, front wheel disk ans caliper , color of the shock Spring are différent (green 89, blue other years... It seems me thé very first 89 has différent crankshaft
i'm French and I don't speak English very well, so, please, excuse me :)
- kx200
some of the early 89's serial # used a bolt for the magneto and the newer # uses a nut like all the rest of the KDX models
Ffryno13
So should I look for a later motor that has common parts. I'm also looking out for parts availability.
sarrant
By "later motor" do you mean an H-Series or a newer E-Series?
I wouldn't bother hunting a newer E-Series for parts availability, as it is much the same as what you have, and what isn't is generally interchangable. H-Series engines, of course, are gonna have a much more plentiful parts supply
