clutch hub nut removal
bultaco4ever
Post by bultaco4ever »
I tried using my air impact driver to zip the nut off. My compressor is only 140 psi. The nut didn't budge. How do y'all do it? Does nut need heat first?
kx200
Post by kx200 »
air gun should do it. I run my gun at only 100psi and it is only a 3/8 drive.
bultaco4ever
Re: clutch hub nut removal
It's not LH thread, is it?
Tedh98
Been thanked: 2 times
Post by Tedh98 »
bultaco4ever wrote:It's not LH thread, is it?
No
bultaco4ever
I am having no luck removing this nut.
Tedh98
Post by Tedh98 »
Have you tried adding a pipe or something else to the end of a ratchet to get some more leverage on it?
I'm not sure what the spec is on an E, but I believe the H is 65 ft/lbs. But I think they go way past that at the factory because removing a virgin nut can take some effort.
Has thanked: 1 time
Been thanked: 6 times
Impact gun works for me easily every single time.
koshari
Post by koshari »
Good thing i pack one of those these days nick.
Sent from my SM-T210 using Tapatalk
bultaco4ever
Thanks for the suggestions, so far. I suspect that my air impact wrench is bad. I just borrowed an electric impact wrench. I'll give it a try tonight. I'll let you know if it works.
bultaco4ever
Yes...the electric impact wrench removed the nut very easily.
Falcon911
Post by Falcon911 »
I had the same - huge extender bar with socket, bike in gear and stood on the rear brake. It wouldn't move.......took about two seconds with an 18v impact wrench. Brilliant tool!
