KLX 650
luisrspereira
KLX 650
Post by luisrspereira »
Anyone now if is possible the conversion of the KLX 650 fork on a KDX 200 1998
canamfan
KLX 650
Post by canamfan »
You can cross reference the bearing sizes on All Balls website but why would you want the klx 650 forks they are an old design, conventional. I don't see any upgrade in using them.
sarrant
KLX 650
Post by sarrant »
KLX650 forks are inverted. I think they're a variation on KLX300 forks, and likely bolt straight on.
KLR650 forks are conventional.
canamfan
KLX 650
Post by canamfan »
My mistake I was thinking klr
6 Riders
KLX 650
Post by 6 Riders »
sarrant wrote:KLX650 forks are inverted. I think they're a variation on KLX300 forks, and likely bolt straight on.
luisrspereira wrote:Anyone now if is possible the conversion of the KLX 650 fork on a KDX 200 1998
Yes, but any 650 fork is gonna have some beefy springs in it.....650s are HEAVY bikes r/x doesn't matter, there is a lot of weight built into those machines and I'm sure the X is sprung properly for it. So plan on at the least putting a set of springs in (not that any other conversion would be different) and a re-valve.
sarrant
KLX 650
Post by sarrant »
According to the parts diagram, they are .43 kg springs stock.
luisrspereira
KLX 650
sarrant wrote:According to the parts diagram, they are .43 kg springs stock.
and the kdx??
luisrspereira
KLX 650
and the kdx??
It is good for my 185 lbs?????
Re: KLX 650
Are you 185 in gear or just 185 by yourself?
Pretty smart to get the more heavily sprung forks.
KLX650 should be as KLX300 or older KLX250.
luisrspereira
Re: KLX 650
Jason wrote:Are you 185 in gear or just 185 by yourself?
my wheight is 84 kg = 185lbs
Re: KLX 650
so 200 pounds in full gear??
.43 will be very good.
luisrspereira
KLX 650
Jason wrote:so 200 pounds in full gear??
Anyone now if the KDX wheel is compatible
sarrant
KLX 650
Post by sarrant »
I'd take a look at any of the other KLX conversion threads in this subforum. It's likely pretty much the same.
