I'm new here !!!
Sgt.harper48
I'm new here !!!
Post by Sgt.harper48 »
Hi everyone. I'm new to off road. Decided to buy a 2003 KDX200 last weekend on a whim. Priced at 900 with a title and running. Upon bringing it home it feels like the kick start doesn't have enough "tension" or resistance when trying to crank. Found fresh oil build up all around where the exhaust comes out of the motor and it doesn't idle very long with or without choke on. As far as I know I feel like it was worth the 900 bucks. Just hoping none of these issues are serious or expensive fixes. I have ordered a fmf power core 2 exhaust for it. Gold series fatty next week. And mx style rear fender the week after. Now back to me, I am from central Florida and looking for people to ride with and learn from. Thanks to the site owner for putting this place together !!! Will make a donation asap.
Has thanked: 50 times
Been thanked: 17 times
Re: I'm new here !!!
Welcome to the site and congratulations on your KDX.
Sgt.harper48
Thanks Jason !
KDXohio
Post by KDXohio »
welcome should be minor the o-rings on the pipe could be missing or worn causing the splooge to leak out. Do a compression test to get an idea of the top end condition before you try re jetting or anything else to fix the way it runs if the top end is worn out you'll chase you're tail trying to get it to run right and will only get it right once the top ends done.
kx200
I'm new here !!!
Post by kx200 »
look up the exhaust to see how the rings look.
Sgt.harper48
ok makes sense. Will check that out !
Sgt.harper48
And the seller did tell me the bike sat more than he rode so maybe dirty carb ? Bad fuel ? Lines too ?
