2001 kdx 220 inverted fork conversion
Motomaster707
Hey guys! New to the board and new to the KDX family. I have a 2001 kdx 220 and am looking for the best way to change the front forks to inverted. I do a lot of high speed whooped out roads and occasional moto. What forks will fit and triple clamps. Also possibly shock too but more concerned about the forks. Thanks for any help and advice.
- Has thanked: 1 time
- Been thanked: 5 times
There is an entire section of this forum devoted to fork swaps. Give it a read through.
- Actionman
Re: 2001 kdx 220 inverted fork conversion
Long answer: kx forks can be used but usually need knurling of the kdx stem so the kdx stem can fit into kx triple clamps, and a kx front wheel and brake needs to be used. Has rebound and comp adjusters, but forks may need shortened to keep your kdx from looking like a chopper. Lot more work.
2002 KDX 200
- Actionman
I just noticed my "short answer" is longer than my long answer lol.
2002 KDX 200
cornishwrecker220
1990 kx 125/250/500 forks & triple clamps will slot straight in with no work, the stops on the yokes line up & you can use the kdx wheel & axel & speedo drive...you will need to use the kx brake caliper.
- KDXohio
This is what i used and i love the setup! I have an extra 90 125 front end if your from ohio id be willing to sell itcornishwrecker220 wrote:1990 kx 125/250/500 forks & triple clamps will slot straight in with no work, the stops on the yokes line up & you can use the kdx wheel & axel & speedo drive...you will need to use the kx brake caliper.
Motomaster707
