H hub on E kdx
ladyboys
H hub on E kdx
Post by ladyboys »
Im trying to fit a kdx 220 1997 rear hub on my 1994 kdx 200.
The caliper is touching the hub, what I can do to solve this problem?
6 Riders
Re: H hub on E kdx
Post by 6 Riders »
Do you have the spacers in correctly? My wheels swap straight across from my E to H 200s.
ladyboys
H hub on E kdx
Post by ladyboys »
there is one seal and one spacer on each side, right ?
6 Riders
Re: H hub on E kdx
Post by 6 Riders »
Yup.
ladyboys
H hub on E kdx
Post by ladyboys »
the disc seem too big
ladyboys
H hub on E kdx
Post by ladyboys »
is this normal that the diameter on this hub where the brake disc sit is bigger thant my 1993 kdx hub ?
ladyboys
H hub on E kdx
Post by ladyboys »
this is the H wheel I bought,
6 Riders
Re: H hub on E kdx
Post by 6 Riders »
Well, I just got home, went out to the garage and looked at the three H series rears that I have......Your wheel is not an H series rear wheel. Might be off of a KDX 250 or KX 125/250.
newbbewb
Re: H hub on E kdx
Post by newbbewb »
bummer if it doesn't fit, thats an aftermarket excel wheel. good stuff.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
6 Riders
Re: H hub on E kdx
Post by 6 Riders »
newbbewb wrote:bummer if it doesn't fit, thats an aftermarket excel wheel. good stuff.
Stock KDX rims are Excel Takagos, same thing as that one.
ladyboys
H hub on E kdx
Post by ladyboys »
where I can find a smaller brake disc that fit this hub ?
Been thanked: 6 times
Re: H hub on E kdx
Stock KDX rims were NEVER Takasago Excel's. The rims might be made by the Takasago rim company, but they are NOT Excel models.
That does not look like the stock rotor for 1995+. What is the OD of the rotor?
How many feet do you think you will ride on that sprocket before the teeth fly off? That is horrible. :oops:
Are you sure the wheel is from a KDX? Does the hub have four digits on one of the inner flanges?
sarrant
H hub on E kdx
Post by sarrant »
My '94 most def has Takasago Excels.
ladyboys
H hub on E kdx
Post by ladyboys »
I dont see a four digit on the inner flange of the hub
I dont know why caliper dont fit, both wheel have same rotor diameter, its juste the inside diameter that are not the same ( diameter of the hub)
my 93 kdx 18'' vs the supposed to be 97 kdx 220 19''
97 wheel hub dia. sproket size
my 93 kdx wheel hub size sproket size
my wheel rotor dia.
ebay wheel rotor dia.
my wheel bolt to bolt dia.
ebay wheel bolt to bolt dia.
ladyboys
Re: H hub on E kdx
Post by ladyboys »
Spotted these numbrr
H hub on E kdx
sarrant wrote:My '94 most def has Takasago Excels.
I was just saying that stock KDX rims were not Excel models made by the Takasago company. They may have come stock with Takasago OEM spec rims, but they did not come with the Excel model.
To the main poster, it is odd that it has a 19" rim / tie /etc. on a "supposedly" KDX wheel. Can you put a wooden dowel inside the hub and compare the two widths to see if that helps you? Maybe it is just too wide to work, even if it is an H hub??
ladyboys
H hub on E kdx
Post by ladyboys »
seems to go on a yz...
I love ebay
sarrant
H hub on E kdx
Post by sarrant »
Mine are Takasago 'Excel' branded.
sarrant
H hub on E kdx
Post by sarrant »
ladyboys wrote:seems to go on a yz...
I love ebay
Seems to be a clear case for a refund: Item does not match description.
ladyboys
H hub on E kdx
Post by ladyboys »
sorry to go off topic but its the first time im doing a refund on ebay, will he pay me back the shipping cost ?
thank you
