Reed valve arrow?
ckelly33
Reed valve arrow?
Post by ckelly33 »
Reed valve has an arrow on it, is the arrow supposed to tell me which way to put it in?
s10gto
Reed valve arrow?
Post by s10gto »
Not sure on arrow ,but the rounded tab (A) on the cage should be on the lower left side of the engine/bike.
s10gto
Reed valve arrow?
Post by s10gto »
Here ya go. Lower pic. :grin:
Tedh98
Been thanked: 2 times
Re: Reed valve arrow?
Post by Tedh98 »
If you put it in wrong, you'll be able to tell:
ckelly33
Post by ckelly33 »
Mine has an arrow on the metal piece that if you put it in one way it faces down and if you flip it up and put it in it will point up. It'll go in either way. Also my o rings are worn out on the head pipe could that prevent it from running? Oil was coming out pretty significantly
s10gto
Reed valve arrow?
Post by s10gto »
No if the pipe was missing it would still start.
KDXohio
Post by KDXohio »
Probably fouled the plug try a new plug
