Need torque specs asap
Locked
gabegambale
Post by gabegambale »
Need torque specs for clutch basket bolt clutch spring bolts , water pump primary main bolt ( the big one) please riding on Sunday got fix this thanx
s10gto
Re: Need torque specs asap
Post by s10gto »
Getting book stand by......
gabegambale
My man :supz:
kx200
Post by kx200 »
clutch basket bolt is 65 ftlb
s10gto
Post by s10gto »
clutch spring bolts 78 in-lb
water pump impelller nut 87 in-lb
gabegambale
Got it , still need clutch spring bolts and the other big bolt on the right of the clutch basket I think it's the water pump primary
gabegambale
IIts two gears that have a key way in it 22 mm bolt
s10gto
Post by s10gto »
do you see it? T5?
gabegambale
Yes t5
s10gto
Post by s10gto »
58ft lb
gabegambale
Thank you your the man don't let anyone tell you different :partyman:
s10gto
Post by s10gto »
Anytime! Have a safe ride! :grin:
Corey
Post by Corey »
THIS is a perfect example of why I love this sight!!!
KDXKLXKLR
Post by KDXKLXKLR »
Lower Triples pinch bolt Torque specs?
Has thanked: 104 times
Been thanked: 26 times
Please start a new thread specific to your question instead of digging up a 5 year old one. Thank you.
Locked.
Locked
