PC Platinum 2 and kick lever
Silverfox
Just put the pipe on and noticed the kicker contacts the pipe when folded in. Is this normal? I've never saw this mentioned when researching pipes.
- 6 Riders
Re: PC Platinum 2 and kick lever
Try clocking the kicker one notch and see if that helps.
koshari
mine just touches my kx125 kicker, I ground the end of the kicker on an angle so its not as pronounced.
Silverfox
I thought about clocking it but even if I did, in order for it not to touch the pipe it would be sticking out to far when folded in. It's contacting at the half way point of the kicker and the tip is touching where the pipe mount meets the pipe. I might just find something that won't cook on the pipe and wrap the kicker with it.
canamfan
I have a pc platinum pipe older version and my stock kicker does not touch. The kicker is basically parallel with the frame.
Silverfox
Interesting, I think the PC2 might be wider. How do you like that pipe? You on a 200 or 220?
GI_JO_NATHAN
I don't believe my lever touches my Platinum 2.
I can check when I get home.
Silverfox
canamfan
Silverfox
Well don't I feel stupid. After looking at some photos of other Kdx's with the pipe I realized what is meant by clocking it. I thought u guys meant rotate it out. Anyways I appreciate the help. Thanks.
