Flat rear
- JFortner5
Flat rear
Hey guys this is a dumb question, but I be never had to deal with it. I have a flat rear tire from riding yesterday. By the time I finished washing bikes I didn't feel like messing with it.
I know how to remove the wheel and tire from the bike, but I've never removed the tire from wheel.
Do I need any special tools or anything? Any pointers?
Thanks,
Joey
Thanks,
Joey
- IDRIDR
Re: Flat rear
Look at this: http://www.advrider.com/forums/showthread.php?t=50717
And go spend some time on youtube. There's a wealth of pointers out there.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- Has thanked: 102 times
- Been thanked: 26 times
Re: Flat rear
The Zip-ty tire mounts are awesome! Look into those.
- JFortner5
Re: Flat rear
Thanks guys, that link was great.
After a couple bleeding knuckles, a few choice words, and one ruined new tube, I got it done.
It's actually easier than I thought once I figured out a few little tricks.
- JFortner5
Re: Flat rear
Well I went the put the wheel back on the bike and noticed a small pebble between the bead of the tire and wheel. I deflated the tube and tried to get it out but it fell into the tire.
I'm guessing that's not good. Should I take it back off before I ride?
- diymirage
Re: Flat rear
JFortner5 wrote:Well I went the put the wheel back on the bike and noticed a small pebble between the bead of the tire and wheel. I deflated the tube and tried to get it out but it fell into the tire.
I'm guessing that's not good. Should I take it back off before I ride or after I push it back home with another flat tire?
you tell me ;)
-1997 KDX 220 project bike
- JFortner5
Re: Flat rear
I like what you did there. It's a good point, and it will give me some more tire spoon practice.
- diymirage
Re: Flat rear
nothing wrong with practicing on the spoons
be sure to keep the bead of the tire in the smallest part of the hub, never pull the spoon passed a 90 (or you risk pinching the tube) and use plenty of windex
- 6 Riders
Re: Flat rear
Some "tricks" to tire mounting;
Use baby powder on the tube, helps prevent pinches and the tube will move freer inside the tire.
When dismounting both sides of the bead, take the beads off of the side that they bead onto. This leaves the rim in the middle of the tire, then remove the tube, push wheel into the tire, turn wheel sideways and pull it out.
- JFortner5
Re: Flat rear
I got home from work, took the wheel back off the bike, got the tire off and cleaned everything really good. I used some baby powder on it and a little soapy water just on the bead.
It went much easier this time, and the best part is no pebbles and no leaks.
- 6 Riders
Re: Flat rear
Nice, good job. The hardest part is doing it again and again. I have 11 bikes in the stable and get plenty of practice, but the first tire changeJFortner5 wrote:I got home from work, took the wheel back off the bike, got the tire off and cleaned everything really good. I used some baby powder on it and a little soapy water just on the bead.
I now have a 20 gallon drum to change them on and that makes a huge difference. I suppose with the amount of tires I seem to go through, I should buy a nice stand and mounter.
- JFortner5
Re: Flat rear
I used an old atv tire my neighbor has. It worked okay and there are only 2 bikes here.
I've heard about small tires, I'm not looking forward to changing the ones on the CRF50.
- 6 Riders
Re: Flat rear
Ah, the 50 will be easy. Almost no need for tool on that on.JFortner5 wrote:I used an old atv tire my neighbor has. It worked okay and there are only 2 bikes here.
newbbewb
Re: Flat rear
6 Riders wrote: BTW there is NOTHING worse than changing a tire on a KX65![]()
Try a sport bike. Then you'll love changing tires on the kx65.
