Well, I found one. I picked it up from the Post Office today and just got it home. I fear that it's not going to be as direct a swap as we had hoped, but I'll get to that in a minute. My goal here is to figure this situation out and document the whole process so that the information will be out there and hopefully helpful to the KDX community. My initial impression is that this is a project that will benefit from having a number of guys who know their stuff thinking about it. I know that there's a lot of interest in getting more lighting power out of our bikes. As a side note, I was reading through the Baja Designs literature about their Dual Sport Lighting Kits and they say that they make a special lighting coil for the KDX that puts out 120 watts. That sounds very interesting. I haven't looked into that any further but that could be very cool.
Back to the SR stator. I'm just focusing on the mechanical aspects before I get into the electrical aspects. Here are a few pictures of the SR stator compared to a US-spec stator. The biggest difference other other than the number of coils is that the ignition source coils are 180 degrees apart. I consider myself a pretty good 2-stroke mechanic but this brought up a glaring lack of knowledge about how an ignition like this triggers the spark. I know the source coil provides the energy to fire the ignition but I don't know what triggers the ignition event in a CDI ignition. This could be a serious problem if the triggering mechanism is also 180 degrees out. I need to figure out whether or not this is the case before I start trying too hard to solve it. If so, the first things that come to mind are to find an SR flywheel or to have a keyway cut into the US flywheel 180 degrees from the original one. That should locate it properly. But maybe I'm getting ahead of myself.
The second potential problem is that the lighting coils are taller on the SR stator. I'm not sure whether or not it would fit under the US flywheel. I'll start looking into that one in the coming days. This might not be a really fast-moving project since I have a lot of other stuff going on, but I wanted to get the ball rolling. Hopefully some of you guys can chip in with some insight.
