jetsrus pwk carbs
A reference for the PWK carbs...
canamfan
jetsrus pwk carbs
Post by canamfan »
I've been looking at the pwk 35 mm carbs on jetsrus, standard and airstriker. The pwk35mm has 160 main, 68 pilot, 48djk needle, and 6.0 slide. The airstriker 35 mm has 160main, 48 pilot, 48dek needle, 4.5 slide. Prices are good $176.85 for 35 pwk and $186.15 for 35 airstriker. I'm guessing the larger pilot on the standard pwk is because of the 6.0 slide. Have any of the carb gurus on here tried either of their carbs? Price is pretty hard to pass up. I'ts 15 degrees here this morning in Missouri so not much to do but look at stuff on the computer. :grin:
Has thanked: 13 times
Been thanked: 26 times
Re: jetsrus pwk carbs
The airstriker is a bit of a different animal, but a very nice carb. I would go that route if I were goin. You're going to have to jet it to your bike, regardless which option you go with.
