coolant change procedure
dualscotty
Hi there.changed the coolant in my 98 today.drained it from water pump.emptied resivour bottle.....filled radiator slowly.filled resivor bottle to full mark.ran bike with cap off .the manual says to bleed air on top of cylinder. Is this neccisary.if so do with engine off...thanks
BlackMist
Re: coolant change procedure
Yes it's necissary to bleed air from the screw, air pockets can cause pretty gnarly damage. Do so with engine off, and you want a solid stream, no bubbles. Be quick with the screw as it's not a long process haha and makes a mess
- Gotanubike
Also make sure the rad cap is removed when you crack the bleeder obviously if the cap is left on it will create a vacuum and it won't work...
I usually bleed the air after every ride, there always seems to be some air introduced after a long ride
1990 KDX200
motoracerx
Especially when the bike seems to be upside down more than right side up on my rides.Gotanubike wrote:Also make sure the rad cap is removed when you crack the bleeder obviously if the cap is left on it will create a vacuum and it won't work...
dualscotty
Mines usually upside down a lot as well.thanks for the info.can engine be cold or should it be warm like shortly after its been running? Thanks
- Been thanked: 19 times
Engine warm is best. I've even done mine with the engine idling as per the FSM and no issues.
