6 riders, Thank you very much :-) but I'm looking for an aluminum color wheel, and anyway I think shippingwill be a deal killer... So make your whell builder happy
diymirage: in the first time I thought to keep my 93 KDX front wheel and change the bearings and spacer but for this adaptation the bearing required seem to don't exist..
You're right, but the problem is : I find the OEM number (41034-1226) for the entire hub (hub, seals, bearings, spacer), I can not find a number for the naked hub, so I can't find other machines (other than 125/250 KX 93-98 500KX 94-04) using the same hub .... :-(
Here's why I asked if anyone know of other wheels / hubs compatible with a KX 94-98 fork...
edit: i see the sames hub bearings (92045-1284 ) are used on lot of kx and kxf, but what about the largest of the hub and compatibility with: have wheel centered, brake disk with good diameter, and disk at the right place in the calipper
