front fork free sag
A service reference
twowheelfanatic
front fork free sag
Post by twowheelfanatic »
on a 2000 kdx 200 how much free sag should it have?
Has thanked: 108 times
Been thanked: 30 times
Re: front fork free sag
roughly a third is what I have read.
IDRIDR
Post by IDRIDR »
A third of what?
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
Sullyfam
Post by Sullyfam »
I'd guess a third of total sag. Never heard of that, but I could see that (free sag and a % of race sag) being something to consider. Suspension gurus think of all sorts cool metrics...
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Dwight Rudder's formula:
Front suspension static sag should be 14% ( available travel in mm X .14 = static sag in mm)
Front suspension rider sag should be 25% (X .25 = Rider sag)
Rear suspension static sag should be 11% of available travel (X .11 = static sag)
Rear suspension rider sag should be 34% of available travel (X .34 = rider sag)
IDRIDR
Post by IDRIDR »
You have me confuzzled. The front fork free sag (no rider) should be 1/3 of total travel?
Free sag is without rider, isn't it? Bike weight only?
Just learning here. . .
2014 Suzuki DL1000.
twowheelfanatic
me too.1/3 of total travel for free sag bike weight only seems excessive?
Sullyfam
Post by Sullyfam »
Sag or race sag, as I understand and use it, is measured by subtracting the length of travel when the bike is sitting on a stand with no weight (I.e. Wheels in then air) minus the length of travel with the rider on the bike fully suited up. This distance is typically 100-110 millimeters or 4 to 4.3 inches, which would put it at roughly 1/3rd the shock tracker of 12". Free sag I thought was the distance between the bike on the stand minus the distance off the stand but with no rider - or so I thought. I've always set the race sag and never really focused on free sag.
Sullyfam
Post by Sullyfam »
Sorry, meant shock *travel* not shock tracker (dang auto correct!) and when I say free sag it is the same measurement Tedh98 refers to as static sag. Also, my comments refer to the rear shock. For the front I just but the right spring for my worth and roll [emoji51]
my bad
go with what tedh98 reposted from Dwight Rudder.
twowheelfanatic
thanks for the information.thats what i will do.planning on doing forks friday and a test ride saturday here in the midwest
