220 piston
jjavaman
220 piston
Post by jjavaman »
Hi guys, I'm in the process of getting the RB carb/head done so it is time to see if it's a stock or aftermarket piston. I was told when I got bought the bike that it had been rebuilt so I was hoping it was a wiseco piston. Scraped the carbon off the crown and there was a b stamped into it. I look in the exhaust port and see those beautiful machined marks of a forged piston! I did a compression test before I pulled the head and it was 130lbs so I'm a happy camper!
Now my question, I can move the piston with my fingers. With the piston at tdc, I can turn it in the bore, just a bit, but still it moves around. Is that normal?
Tedh98
220 piston
Post by Tedh98 »
jjavaman wrote: Now my question, I can move the piston with my fingers. With the piston at tdc, I can turn it in the bore, just a bit, but still it moves around. Is that normal?
You mean you can move it clockwise/counter-clockwise inside the cylinder? How much does it move?
jjavaman
Re: 220 piston
Post by jjavaman »
That's right, it moves maybe a 1/16 " clockwise/counterclockwise.
ohgood
Re: 220 piston
Post by ohgood »
jjavaman wrote:That's right, it moves maybe a 1/16 " clockwise/counterclockwise.
hmmm I'm watching this one for accurate information
pumpguy
220 piston
Post by pumpguy »
If it moves that much, I'd be real curious about the condition of the wrist pin bearing. Is there clunking or any up and down clearance at the piston when you rock the flywheel back and forth?
JasonK94Z
Re: 220 piston
Post by JasonK94Z »
A new piston kit and wrist bearing is pretty cheap. Especially after you've already removed the head, etc. Replacing the piston is also an opportunity to clean the power valves.
2002 KDX 220R
2003 KLR 650
Tedh98
220 piston
Post by Tedh98 »
jjavaman wrote: Scraped the carbon off the crown and there was a b stamped into it. I look in the exhaust port and see those beautiful machined marks of a forged piston!
Was there anything else stamped on the top of the piston? Wiseco's usually have several letters/numbers on the top.
Something doesn't seem right. Since you have the down time, I would pull the cylinder and inspect things further.
jjavaman
Re: 220 piston
Post by jjavaman »
Ya,I'm going to pull the cylinder and clean the kips so I'll look a little closer at the piston then. Don't you love winter down time.
jjavaman
Re: 220 piston
Post by jjavaman »
Hi can someone tell me if this is a forged piston? By looking at some previous posts I'm thinking it is because of the machining marks.https://imageshack.us/my/images https://imageshack.us/i/eys6RaYJj
Tedh98
Re: 220 piston
Post by Tedh98 »
jjavaman wrote:Hi can someone tell me if this is a forged piston? By looking at some previous posts I'm thinking it is because of the machining marks.https://imageshack.us/my/images https://imageshack.us/i/eys6RaYJj
What is on the top of the piston? It should have Wiseco's P/N.
jjavaman
Re: 220 piston
Post by jjavaman »
https://imageshack.com/i/exkFtWrVj All it has in the top of the piston is a B and a arrow. Hope this helps.
Tedh98
Re: 220 piston
Post by Tedh98 »
If that is all it has on the top then it isn't a Wiseco.
Tedh98
Re: 220 piston
Post by Tedh98 »
Now with the cylinder off, what is loose that causes the piston to rotate?
IDRIDR
220 piston
Post by IDRIDR »
My 'assumed' stock 220 piston looked like that on top except it had a "C" instead of the "B."
I meant to find it last night and look at the side.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
jjavaman
Re: 220 piston
Post by jjavaman »
Well I've decided that it's a stock piston,reading the manual it talks about the piston having a A or a B on the top and mine does. There is a lot of slop in the wrist pin,back and forth movement so I'm going to order me a wiseco.
Has thanked: 9 times
Been thanked: 17 times
Re: 220 piston
You'll want a top end kit, or get the gasket set and wrist pin separately. Piston kit does not usually come with wrist pin bearing.
pumpguy
220 piston
Post by pumpguy »
If that excess clearance is due to an oversize bore in the connecting rod, a new wrist pin and roller bearing assembly won't solve the problem. I would suggest you remove the piston from the rod, and check the clearance with just the wrist pin and roller bearing assembly. If that bore is worn oversize, a new rod is probably the best solution.
