Is it a 200 or 220?
motoracerx
Is it a 200 or 220?
Post by motoracerx »
How can you visually tell the difference between a 200 and a 220? Bike is an 03.
There are no decals representing either model on the bike.
Is the engine displacement on the motor anywhere?
6 Riders
Re: Is it a 200 or 220?
Post by 6 Riders »
Yes, the cylinder has the size on it. It's on the right hand side of the motor, where the reed cage meets the cylinder. it will either have 0.198l or 0.219l (I think) on it....
IDRIDR
Post by IDRIDR »
6 Riders wrote:Yes, the cylinder has the size on it. It's on the right hand side of the motor, where the reed cage meets the cylinder. it will either have 0.198l or 0.219l (I think) on it....
Like this?
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
6 Riders
Post by 6 Riders »
Yup, like that...the .218 (not .219) is a 220, .198 is a 200.
216??
Without having both side by side, I can't think of any other difference to differentiate between the two.
motoracerx
Thanks fellas.
It was advertised and sold as a 2003 kdx 220 to me.
It is in fact a 200. Not a big deal I guess.
Research tells me that the 200 may be favored over the 220 anyway.
koshari
Post by koshari »
Jason wrote:216??
Different carburetors.
kx200
Is it a 200 or 220?
Post by kx200 »
center power valve is different
12005-1273 for the 220
12005-1274 for the 200
IDRIDR
Is it a 200 or 220?
Post by IDRIDR »
koshari wrote:
Jason wrote:216??
Different carbs as stock, but they could be switched around with some preferring the 200 carb on the 220.
kx200 wrote:center power valve is different
Good to know. Are there some instructions for removing this piece. When I had it apart for service a month or so ago, I could not remove those parts. Are they pinned in? I cleaned and scrubbed on them with carb cleaner. But I could not determine from the manual or from searching around here how they'd come out.
I'll have to look at my cylinder to see if the number is 0.218 or 0.216l. In either case, are the 200 cylinders marked 0.198l?
2014 Suzuki DL1000.
G22inSC
Post by G22inSC »
I believe he is looking for external, visual differences. There are several internal differences related to ports, pistons, etc. The only external I know of besides the cylinder markings, OE graphics and possibly the carb, is the chain. Factory 200s had regular chains while factory 220s had o-ring chains if I'm not mistaken. Not likely you would find an OE chain after all these years though.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
G22inSC
Post by G22inSC »
Noticed something tonight for the first time, probably since it was dark in the shop and had a shop light laying on the floor. If you look under the case on the left side (stator side) there is a flat spot just above the drain plug. That spot has a stamped sequence of numbers on it. Mine started off as "DX200..." I'm guessing that means my motor left the factory as a 200cc KDX (which I know for certain since I bought it new). Can anyone confirm if a 220cc is stamped DX220...? If so, it's a good way to know what the bottom end was originally and if it matches what cylinder is attached.
'08 Kaw KX65 (Sold)
Gallery
IDRIDR
Post by IDRIDR »
Good eye. Mine says DX220.
And it looks like 0.216 l on the side, which matches the manual spec.
2014 Suzuki DL1000.
diymirage
Is it a 200 or 220?
Post by diymirage »
200 has an X chain, 220 has an O-ring chain ;)
(Or they did when they first left the factory)
-1997 KDX 220 project bike
Thanks for the info on the engine number.
Do the carbs look physically different on the outside?
newbbewb
Post by newbbewb »
Nope, the carbs are same casting between the two bikes, just different bore size. They are identical on the outside.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
