Bad Craigslist deal.
diymirage
Re: Bad Craigslist deal.
Post by diymirage »
omeltono wrote:Ahahah man, what a deal. I have a bike though, how about 1500 for the manual
if you really need one that bad ill sell you mine for $1200.00
ill even include free shipping
-1997 KDX 220 project bike
G22inSC
Post by G22inSC »
Hope it's printed on gold leaf paper for that going price.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
Has thanked: 10 times
Been thanked: 17 times
omeltono
Post by omeltono »
Haha wow, that ones a lot cheaper than the one you guys are trying to sell me [SMIRKING FACE] thanks for the link Julien!
omeltono
Post by omeltono »
ImageAlright guys just got it today. They only took off the clutch cover. But inside they found this. Any suggestions?
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Look here:
http://www.kdxrider.net/forums/viewtopi ... iew=unread
So are you saying the shop didnt split the cases?
omeltono
Post by omeltono »
No the shop didn't split the cases. Thanks for that link, looks like that's where I'll find my answer
Tedh98
Post by Tedh98 »
Gotta love that first gear second gear are shot diagnosis.
Dekon
Post by Dekon »
That's the remains of the KIPS governor shaft pin.
omeltono
Post by omeltono »
To replace it do I have to take split the engine? Or can I just take off the kips cover?
Tedh98
Post by Tedh98 »
Just take off the larger cover on the clutch side.
diymirage
Post by diymirage »
yup, about a 5 dollar part
plus a 4 dollar gasket, and 12 dollars for shipping and your bike will be running like a choo choo train...how are we feeling about that bad deal now ?
omeltono
Post by omeltono »
Fantasticcc [THUMBS UP SIGN]
omeltono
Post by omeltono »
Alright. I've found the part, thank you guys for everything and I'll let you know if/when I get it up and running. Now is there any other parts I should order while I'm in this side of the engine?
Dekon
Post by Dekon »
I'd do a water pump seal while it's apart.
omeltono
Post by omeltono »
Could I do a liquid seal?
diymirage
Post by diymirage »
Dekon wrote:I'd do a water pump seal while it's apart.
it wouldnt be apart, you can take the inner clutch cover off without disturbing the water pump
might even be able to do this job with only the outer clutch cover off but i doubt it
omeltono
Post by omeltono »
Alright so just got around to taking the beast apart. Not far into the project the longer screw on the clutch cover appears to be stripped, so as of now I'm at a standstill. More help pleasee
omeltono
Post by omeltono »
I do have a screw extractor kit put I'd prefer a safer way if possible
diymirage
Post by diymirage »
a couple of options
is it sticking out far enough to get a pair of locking vice grips on it?
if not, you may have to get a dremel with a cut of wheel and cut a slot in it so you can use a flat head screwdriver
you might get lucky and be able to flatten the head with a hammer and then remove the screw with an impact screw driver (really a necessity with any motorcycle)
the last (and perhaps easiest) option is to get a drill bit one size larger then then body of the screw and just drill the head off
once all the other screws are out and the cover is removed you can get the vicegrips on the shaft of the screw and remove it
