Seems FMF does not list a spring and o ring kit for a KDX220. Does anyone know what will work?
T
FMF spring and o ring kit for 220?
TAT2
- diymirage
Re: FMF spring and o ring kit for 220?
not sure about the o rings (i always one the ones included in the top end kit) but the last time i needed springs i just walked into my local bike shop and they pulled a set from the shelf
i think they were 75MM but im not sure
-1997 KDX 220 project bike
TAT2
I am a noob.... so I did not know the o rings came in a top end kit. I may need to put in a Wiseco. I need to check compression still and what piston is in it.
T
T
Fitterman24
Ebay has springs--even in stainless steel. Just a upper end gasket set has the o-rings. I used a set of o-rings from the local Ace Hardware store. They worked just fine with some high temp silicone.
TAT2
Is there something else that fits between the pipe and cylinder other than an o ring?
T
T
