Quick question
KDX_Johnny
Quick question
2006 KDX200: I noticed the other day that's the brake line that comes off my rear master cylinder goes forward and then loops backwards towards the rear brake. BUT while the brake line is doing that loop I noticed it rubs against the rear shock spring.... So much so that it's actually wearing the paint off the spring. Does anybody else's bike do this? Is it okay? Should I move the brake line over? I really don't care about the spring. I just don't want my brake line to be worn through.
Just a square trying to ram myself into that circular hole...
- Has thanked: 15 times
- Been thanked: 28 times
Re: Quick question
I would try to route the brake line in such a way that it does not rub anything, yes.
cornishwrecker220
Quick question
Quick simple fix....
Unbolt & remove the rear caliper leaving the brake line still on ...
Pull straight..
Rotate the caliper `CLOCKWISE` 1 turn should do...
Keeping everything tight....refit......it now shouldn't touch or rub the spring !
Pull straight..
KDX_Johnny
