which carb uses more gas??
- Ryan
just wondering if a 200 carb would use than a 220 carb?? it would be on a kdx220. Also, with the kdx220 would i have to shift more or would it be the same? thanks
- m0rie
That would depend entirely upon the jetting. The carbs are the same, the only difference is the bore size and the jets. A 33mm (220 carb) and a 35mm (200 carb) both jetted with identical 150, 45, CEL#3, TV#5 jetting on the same bike would use the same amount of fuel. The amount of fuel being correct for the amount of airflow is another thing entirely.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Green Hornet
Yeah, What he saidm0rie wrote:That would depend entirely upon the jetting. The carbs are the same, the only difference is the bore size and the jets. A 33mm (220 carb) and a 35mm (200 carb) both jetted with identical 150, 45, CEL#3, TV#5 jetting on the same bike would use the same amount of fuel. The amount of fuel being correct for the amount of airflow is another thing entirely.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
The one that has the bigger sprocket...
- Has thanked: 153 times
- Been thanked: 38 times
Just to play devil's advocate, I will say the 220 with a 35mm carb will suck down the most gas since it has 18cc more room to hold a good breath of fumes.
Besides... you can't shift with a carb to easy....
Do you already have a 200 carb? Didn't you make a post a little while ago stating that you wanting to do the bare minimum to your KDX so you could get a street bike??
- m0rie
- m0rie
Take a deep breath. Continue to hold breath until you pass out. When you wake up realize that having a 35mm carb on your 220 is a good thing. You should not trade it under any circumstance. If you relapse go back to the beginning and start over.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Green Hornet
Continue to hold breath until you pass out.m0rie wrote:Take a deep breath. Continue to hold breath until you pass out. When you wake up realize that having a 35mm carb on your 220 is a good thing. You should not trade it under any circumstance. If you relapse go back to the beginning and start over.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Sounds like you're having Cyper Sexkdx220freak wrote:ok let me tryi, cant do it..... its soo hard.... ahhh..... ahhhh.....ahhhhh..ahhhh.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- m0rie
There is no bottom end to loose. The 220 is starved for air anyway you slice it. Its a fluke that Ma Kawi put a 33mm carb on them. Has to do with the 220 being a road legal version for many years in Japan and other places. The older 200's had to make do with a 28mm carb. Your bottom end is fine. Make sure your jetted right and move along with things.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- Ryan
- m0rie
For the 220 you don't want to get anything other than the weisco piston. The pro-x is an oem replacement and has the possiblity of fragging just like the stock piston.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
