anyone ever seen there water pump primary do this ?????
gabegambale
Post by gabegambale »
has this ever happened to anyone bought the bike from a junk yard this is what I found ,and the water pump impellar is binding up,could that possibly be on backwards
Tedh98
Been thanked: 2 times
Re: anyone ever seen there water pump primary do this ?????
Post by Tedh98 »
Yup, backwards.
gabegambale
ok so the dumb ass who had this bike before me was an idiot thought it looked a lil off I had to look up what the primary looked like then I noticed it looked backwards on the bike thanx
Has thanked: 160 times
Been thanked: 40 times
Hi. I deleted your double post in the Fork Conversion subforum.
Good luck on the rebuild.
gabegambale
thanx Jason I didn't notice it was in that forum till it was too late,soooo dumb question would I be able to re-use this gear if not does anyone know the part number ???
ICRage42
Post by ICRage42 »
I was wondering what became of this.........wow looking at it instead of on my phone shows so much more. Looks like it is also hitting the clutch basket as well.
That gear I wouldn't reuse. If you look at say babbits or Kawasaki parts dealer for oem they usually have a parts diagram that you can see what part number it is.
Well on a good note hopefully it didn't overheat everything else is good just last owner took it to the yard because it had a weird sound on the bottom end from the gear reversed.
Your water pump spur gear is indeed installed backwards. the chamfered face of the gear should face the clutch basket. More concerning is the odd wear pattern of it and the damage tot he primary spur gear...that engine ate part of itself at some point. I'd replace them both .
gabegambale
I thought the crank gear looked weird ,im def going to replace both
