These ran a higher compression and just curious as to the factory spec.
Thanks
Gotanubike wrote:18lbs just feels so not tight that It's not even safe. I'd guess mine are somewhere around 23-25ft-lbs but I go by feel
The modern 4 stroke like the CRF250 " R or X " is a copy of an Indy Car engine . Very short stroke " probably why the low compression " and extremely high rpm's ,, 12-13,000 !Gotanubike wrote:My brothers Honda crf250 head bolts are 29lbs from the Honda manual and they are only 57psi @ 800rpm(kickstarting on dead cold). He was with me the first time doing a reassembly on the kdx motor(mainly because he owns the torque wrench) and he didn't think 18lbs was tight enough either...
For a motor that does twice as many revolutions...I'd have to check but I don't even think they recommend retorqueing the KDX head nuts after the 1st or 2nd ride....torque them down good the first time. More compression, less worry and hassle
Would agree, even is the most important.I hear ya there![]()
Mine are 25 plus but then I was told I'd warp the head ???
If it's torqued evenly , how can that happen ?
