Replate or new cylinder time?
crs
Post by crs »
Just checked the top-end of my new '99 220...
Thoughts please...
(If it does need replating and anyone knows somewhere good to do it in the UK, I'd appreciate the info'.)
Thanks.
diymirage
Re: Replate or new cylinder time?
Post by diymirage »
I would say have it bored over 1.0 mm and replated
I had one of my 200 done by langcourt and was very pleased with the work and the level of communication
(I used their US facility but they actually started out in the UK)
http://langcourt.com/page2.html
since it looks like yours needs a rebore be sure to include the KIPS valves so they can grind the main valve for piston clearance
they should also have the piston you need in stock so just buy it from them and they will match the bore to the piston
im guessing your cost will be about 250 pounds for a bore, replate and top end kit
-1997 KDX 220 project bike
crs
Post by crs »
Thanks for the advice and link - I've sent them an email.
Has thanked: 9 times
Been thanked: 17 times
I'm not sure that would need a bore. I had one much worse off than that and langcourt did some weld repair and then plated back to factory spec.
crs
Post by crs »
Langcourt have said they can replate to standard.
scheckaet
Post by scheckaet »
Julien D wrote:I'm not sure that would need a bore. I had one much worse off than that and langcourt did some weld repair and then plated back to factory spec.
+1
fuzzy
Post by fuzzy »
Indeed, I believe Langcourt will bore out the plating, and replate for no cost. Overbore is additional, and required fee for gouge repairs, etc.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
diymirage
Post by diymirage »
I guess if you weld enough material to bore it back down to stock bore, that's an option aswel :grin:
They won't weld that. They'll just cover it with plating. Mine had some huge gouges and chipped ports from a grenaded piston, hence the welding. That cylinder is fine, it's factory plating is just shot.
diymirage
Post by diymirage »
cool
not like the factory plating is all that durable anyway :naughty:
