Resistor plugs
Dekon
Resistor plugs
My neighbor gave me four brand new NGK B8ES plugs. Do you really need to run a resistor plug in the KDX?
- 6 Riders
Re: Resistor plugs
Isn't the stock plug a B8ES? I know I run resistor plugs, but I didn't think that they where called for.
Dekon
Resistor plugs
My manual states it a NGK BR9ES. A lot of people on this site say to run a BR8ES as a 9 is to cold. Oh yeah, forgot to mention that this an '89.
cornishwrecker220
Resistor plugs
If your neighbour gave you x4 resistor plugs then perhaps he/she is trying to tell you something?
- Joshmcmillan
Re: Resistor plugs
I have always used B8ES in E-series and H-series KDX200's, never had a problem
07' CR450X (Main Bike)
91' CBR250RR
91' CBR250RR
- 6 Riders
Re: Resistor plugs
OK, so the owners manual states that the BR9ES is the stock plug, but ALSO says that the B9ES is usable as an alternative. The B8/BR8 is a little hotter and tends to be recommended in the KDX...I run both and don't truly notice a difference.
Re: Resistor plugs
All the resistor does is minimize RFI (static noise) generated by the plug. On multi cylinder machines with CDIs non resistor plugs could cause enough interference to harm the CDI...could...but doubtful. On the KDX the CDI is very simple and running a non-resistor plug will not damage it. You may , however, hear more static in your interphone system if you run one.
Dekon
- Has thanked: 52 times
- Been thanked: 17 times
Resistor plugs
What year and model KDX is it????????????
Dekon
Resistor plugs
Oops, I thought I had that in the first post. It's an '89.Jason wrote:What year and model KDX is it????????????
Re: Resistor plugs
The stock plug is a B9ES, with no resistor. I never could keep a "9" heat range plug burned off. I had to switch to an "8" heat range. (the B8ES in question)
