Dg enduro pipe
Don
Dg enduro pipe
Is the dg pipe worth the Change over a stock pipe. Was told I could hollow out the stock pipe .is it worth the effort.still using the stock silencer. Thanks don
- Has thanked: 195 times
- Been thanked: 52 times
Re: Dg enduro pipe
What year and model KDX??
- Been thanked: 10 times
Re: Dg enduro pipe
Any change over the stock is an improvement, both in weight savings and performance. Changing pipes will require rejetting.
- Joshmcmillan
Re: Dg enduro pipe
Gutting out the stock pipe on an 89-94 makes a big difference.
07' CR450X (Main Bike)
91' CBR250RR
91' CBR250RR
KDXrider1989
Don
sarrant
Re: Dg enduro pipe
Yes, removing the inner wall of the stock pipe has been reported to give a big boost in performance on the E series. As has pretty much every aftermarket pipe (DG, FMF, Pro Circuit, etc)
- Has thanked: 15 times
- Been thanked: 28 times
Re: Dg enduro pipe
I modded the stock pipe on my 89. It was a lot of work. Eventually I went to the DG pipe and have been very happy with it. I'd recommend just going that route straight off and skip the pain of modding the stock pipe.
shaunkdx
Don
Re: Dg enduro pipe
Thanks for all the replies . I'm going to hollow out the oem and rejett unless I get really get upset trying to remove and clean inside pipe to tig weld
