Looking for new clutch perch
I saw a post a while backbut can find it. I am looking to replace my wore out couch perch and was wondering what the best one to get it? I think the person had a Moose one just want to make sure thanks.
- Joshmcmillan
Re: Looking for new clutch perch
I just go to the nearest bike store and grab a no brand universal perch and lever for $20... But I do break mine regularly so spending more money would be wasted. I had some eBay unbreakables once that lasted a bit longer
07' CR450X (Main Bike)
91' CBR250RR
91' CBR250RR
- diymirage
I think he is looking for some with a specific pull, you can mount up any perch you like (mhhhh, perch) but depending on where to cable sits in the lever it will pull different
-1997 KDX 220 project bike
I have an AVS f5. it's stronger for sure, but run barkbusters and nothing except you will break. the AVS has adjustable pull and cable tension. I like mainly because you can quickly adjust lever height as the clutch heats up.
I have the MSR Pro-Raptor Clutch Lever Assembly Shorty on two of my bikes. It allows for an adjustable pull (I like mine easy as possible) based on which hole you use on the lever. Check it out.
- adam728
I liked the MSR Pro Raptor on my YZ. Seemed a bit sloppy for a needle bearing pivot though. Machining a higher tolerance pivot bolt was always on my to do list, but never happened.
YeahiI am looking for one to have easier pull. Thanks
