Drain Bolt size?
sailorcolin
Drain Bolt size?
Post by sailorcolin »
I have a striped drain bolt, you know aluminium and steel bolt. I am wanting to put in a helicoil but i need to know what size to get. I have it in enough so it leaks very slow but i dont want to remove it until i can put in the helicoil.
Has thanked: 126 times
Been thanked: 33 times
Re: Drain Bolt size?
I want to say 10 x 1.5, but I am not sure.
Look at a Moose racing magnetic drain plug
Gotanubike
Drain Bolt size?
Post by Gotanubike »
Mine stripped last summer too
25/64 drill , 7/16-20 tap, 7/16-20 bolt
There will be a pile of leftover shavings inside the case so you'll have to flush that stuff out at least twice when you're done
1990 KDX200
sailorcolin
Drain Bolt size?
Gotanubike wrote:Mine stripped last summer too
worked well for you?
Gotanubike
Drain Bolt size?
Seemed to do the trick. The bolt always seems to have a little bit of oil on it so it's not 100% but nothing substantial.
1990 KDX200
Yeah, I'd drill and tap to the next size up, you have to do that to install a helicoil anyways, and if you botch the helicoil installation you can have leaks/issues.
Dekon
Drain Bolt size?
Post by Dekon »
I did the same. Works perfect. Put some grease on the drill and tap when you use them and it will hold a lot of the metal chips when you drill and tap it.
Gotanubike
Drain Bolt size?
Yes I actually went back and got your reference from my old thread last summer lol! Couldn't remember the sizes off by heart
1990 KDX200
sailorcolin
Thanks guys!
