Modern Ergonomics
gwynfryn
Modern Ergonomics
Post by gwynfryn »
Has anyone successfully modified (h series) the seat/tank /shroud junction to remove the hump? Something along the lines of the A loop that is available for the xr400.
I wouldn't mind losing a couple of litres fuel capacity if it enabled me to sit further forward. Just trying to wring every ounce of performance out of the kdx and stay competitive against a sea of orange, and thought someone might have looked at this before.
Thanks
scheckaet
Modern Ergonomics
Post by scheckaet »
yup, it's called a kx hybrid :wink:
robkdx
Modern Ergonomics
Post by robkdx »
KX tank and seat may work. Just sold one of each. Doh.
scheckaet
Modern Ergonomics
Post by scheckaet »
I doubt the kx tank would mount on a kdx...
kawagumby
Been thanked: 3 times
Re: Modern Ergonomics
Post by kawagumby »
I found that just using bar risers (necessary for my USD fork conversion) made it easier to move around and forward and I'm 5'10". Also, when I did my USD conversion, the YZ triples I used moved the bars about 1/2" forward - maybe some of the KX triples provide that benefit also.
With those changes I now feel the tank shape was never an issue, it is the low, rearward mount for the stock bars.
With the stock bar location, riding standing was cramped, and it was more difficult to move forward on the bike.
I feel there is absolutely no limitation of movement with the yz USD setup and I suspect other USD setups may provide the same benefit. I have owned a lot of mx'rs so I'm familiar with what to expect, ergo-wise.
You could certainly make it work with enough time and energy, will it ever look quite right is another question. The H took it's perimeter frame from the early 90s 125, but even the pre-94 KX bikes had the saddle look. You'd also have to fab up something for the rear area of the seat as the KDX and KX seat mount points don't match match up. If all you're looking to do is get rid of the crotch trap that is the front part of the seat you could do a custom foam and build that area up, but that would also put you way up on the bike.
sheckaet wrote:yup, it's called a kx hybrid :wink:
Best solution (although admittedly I am biased) Don't immediately dismiss the ergos of the KDX though. Unquestionably of of the easiest bikes to spend hours on, like a Lazyboy on wheels! Update the suspension and you won't even think about that seat. And as stated above, moving the bras up and forward a bit opens up the cockpit as well.
scheckaet
Modern Ergonomics
Post by scheckaet »
moving the bars, getting a different bend and or triple clamp helps a lot.
gwynfryn
Post by gwynfryn »
I may end up going down the hybrid road but my kdx is so sorted in every other respect( 2006,wer, gold valves,rad valve,braided brake lines, gnarly rev and power core etc,etc) and handles well with the conventional forks in our tight forest rides where we average around 20kph.
I stand most of the time but have twice lately come to a sudden stop in a bog after hitting something submerged and slammed my balls against the tank!
My bikes to good to pull the motor from and even ratty kx125's sell for over $2000.00 here.
Has thanked: 30 times
Been thanked: 47 times
bufftester wrote:Don't immediately dismiss the ergos of the KDX though. Unquestionably of of the easiest bikes to spend hours on, like a Lazyboy on wheels! Update the suspension and you won't even think about that seat. And as stated above, moving the bras up and forward a bit opens up the cockpit as well.
Exactly! Personally, I love the antiquated ergos of my E-series. Also, I have never needed to get further forward than what the seat/tank allows.
gwynfryn wrote:...and handles well with the conventional forks in our tight forest rides where we average around 20kph.(14.43mph)
Some USD forks will help a lot to increase your average speed. There is no way I could average 21mph (33.7kph) )on the trails I ride if it wasn't for the USD forks.
gwynfryn wrote:I stand most of the time but have twice lately come to a sudden stop in a bog after hitting something submerged and slammed my balls against the tank!
Better the tank/seat than the bars/triple clamp and possibly going over the bars! :mrgreen:
gwynfryn
Post by gwynfryn »
Better the tank/seat than the bars/triple clamp and possibly going over the bars! :mrgreen:[/quote]
Going over the bars would have been better!
Modern Ergonomics
What I was saying is hitting the triple/bars AND going over! :shock:
6 Riders
Post by 6 Riders »
bufftester wrote: moving the bras up and forward a bit opens up the cockpit as well.
:lol: Usually works for me :supz: :lol:
