Im planning to put the early 1990,s kx250 blue usd forks and wheel onto my 1990 kdx200sr with blue forks.
They are 43mm versus 41mm so I will need to use the kx yokes
Will I need to use the kdx stem and make a spacer for the top or bottom ?
Will I need to use the kx bearings and races
I would like to keep the speedo drive so is it possible to use the kdx front wheel ?
Thanks in advance
kx250 blue usd forks onto 1990 kdx200sr
tight gitt
- Tyl3r
Re: kx250 blue usd forks onto 1990 kdx200sr
For axle and stem info:
http://www.rb-designs.com/KDX-KX-Stem-Swap.htm
For stem bearings:
https://www.allballsracing.com/index.php/forkconversion
For stem bearings:
