I have tracked the problem to the jet needle or main jet passage.
How do I fix this?
Can the part be replaced?
Can I buy a center portion (only 2 screws hold it down)
+1 It gets overlooked usually during carb rebuilds, but when it goes bad you'll never get the jetting right. Not hard to replace (hardest part is getting a stupid security torx bit)Julien D wrote:The most common cause is the gasket underneath that jet block. It's a rubber o-ring type gasket, and if the carb was ever soaked, or dipped, it is likely deteriorated and leaking. I know SUDCO had those gaskets available.
Thanks for that link. Was looking where to buy these parts. I see they sell everything.
bufftester wrote:+1 It gets overlooked usually during carb rebuilds, but when it goes bad you'll never get the jetting right. Not hard to replace (hardest part is getting a stupid security torx bit)Julien D wrote:The most common cause is the gasket underneath that jet block. It's a rubber o-ring type gasket, and if the carb was ever soaked, or dipped, it is likely deteriorated and leaking. I know SUDCO had those gaskets available.
Piet wrote:Pitty: $4 part $20 shipping.
Tedh98 wrote:Piet wrote:Pitty: $4 part $20 shipping.
I take it you aren't in the US?
I just ordered a couple jet block gaskets and a few other items. Shipping was $7. They sent it out same day.
