Too Stupid to Stop: 1983 KDX 250 Resurrection
- kawagumby
- Been thanked: 3 times
Re: Too Stupid to Stop: 1983 KDX 250 Resurrection
Have you thought about putting an H model front end on the bike with disc brake? You can find those very cheap - most guys who put on USD front ends will practically give them away.
dfeckel
If this were more than just a fun bike to occasionally tool around on, then I would seriously consider that option. And who knows? Maybe I'll get the gumption up to do that in the future. For now, however, I think I'll leave it stock. The front brake is actually working to retard forward motion since I replaced the useless plastic Pro Lever. That thing had poor leverage, and it flexed like a bendy straw.
The next likely purchase for this rattler is a new handlebar. The stocker is bent pretty good. Maybe I'll even spring for hand guards...
David Eckel
- Has thanked: 191 times
I missed the race report. Thank you for posting the updates. Thanks for keeping her going and letting us know about it.
alex
help!! my 85 kdx rear shock is worn beyond repair unless there is some sort of magic kdx parts store i can't find on the interweb. anybody that has info on parts or a replacement shock or a way to use something else will help. i'm dead in the water unless i can locate parts. thanks alex
dfeckel
I'm pretty sure you can still find shock head seals for these older KDX shocks. Try Ebay. I have been putting off rebuilding my '83's shock for too long, now, so I'll be shopping for one, too. You may also want to try to find a better-condition used KDX shock from eBay.
I just had the old, old, OLD girl out for a day of riding in upstate NY, and it performed well. I'm still not happy with the carburetion, so I just grabbed an OEM carb off the interwebs and will try that with the recommended jetting specs from Dirt Bike Magazine in '83. I'm also tired of riding with the severely tweaked handlebars, so i grabbed a used set of KLR 650 bars, which appear to have a similar amount of rise built into them (i.e., a lot of rise). I was thinking about the Renthal vintage bend, which have a lot of rise, too, but I just couldn't get past spending $75 on this cheap ass bike.
In other Stupid News, the brakes are actually beginning to work. The rears are still quite touchy and will lock easily in slick conditions, but the front has actually begun to develop half okay stopping power. I guess the new pads have finally bedded in nicely with the drum lining.
David Eckel
l have and 85 250 with a reasonable front brake and a poor rear brake that disappears in water.
I've decided to put a disc on the front for more reliable braking and bought an '86 200 parts bike for the front brake with the bonus of 43mm forks.
The front ends swap straight over between the early mid "80s kdx 200/250 so its a very straight forward job to fit the bigger forks and disc from the 200 to the 250.
Also, as the 200/250 front end swaps straight into the '81 kdx450 lm restoring that also means that disc and 43mm forks from the '86 200 will go straight into the 450 as well.
Cheers
Geoff
Cheers
Geoff
Rd400pi
David,
Do you have an owners manual for this bike? You can get one off of FleaBay for $10 with free ship. Anyhoo, with drum brake bikes, you need to do a special little dance when you install the front wheel. The manual should spell it out but basically you tighten axle clamps and main axle nut in a particular order. Also you are supposed to roll the front wheel a few time and jam on the front brake while the whole thing is up in the air freely spinning. Thus apparently centers the axle. This technique is mentioned in many bike manuals as an important step that will affect how well the front brakes work. This all supposes you still have this bike. My reply is a few years too late.
Cheers,
Mike H.
Cheers,
Mike H.
Yaz
Ok now I really need some good ole help with my 1984 KDX 250 I really need an #21007-1065 Generator Rotor and I already know that most likely they are OBSOLETE. I can't even locate any old 83-84 KDX 250 anywhere online on Ebay/Craigslist. If any of you guys have this part and would love to sale me that one part I would really appreciate it.
Thanks!
Thanks!
Rd400pi
Yaz,
Keep eyeing Fleabay and one will probably show up. Go into the CMS (Consolidated Motor Spares) online and compare the 83/84. I would think they would be the same. Question then becomes: How far back will work? 82...? MZB/Powerdynamo? Good luck.
Mike H.
Mike H.
dfeckel
I haven't been on in quite a while, but I just noticed your front brake advice--thanks! I know for sure that I did not consult my manual when installing the wheel, so that may have been an issue with my crap front brake. Good luck with your project!
David Eckel
Bajarider
You can always reach out to Jeff Fredette at Fredete Racing. He specializes in KDX and if anyone could help you, it would be him.
Rd400pi
Actually called Jeff a couple of years ago (where does the time go?) to talk about 1979 400 and 1983 250 and he said he doesn't do anything with bikes that old. Sounds like he is much more of a modern KDX guy.
Mike
Mike
Baron
- Country: usa
Dfeckel is in my kdx250 hall of heros. This thread gives me alot of hope in my own 1983 kdx250 restoration attempt.
dfeckel
Major props to a fellow member who divulged the "~original" trick to bring back Photobucket images. Now I've resurrected this thead! The bike is long gone (sold it a few years back), but I still love rereading this thread every now and again. I'm so happy I was able to get the images back!
David Eckel
jeswinehart
What a interesting read, can't wait for more.
dfeckel, I rebuild those flywheels + encapsulate the magnets (70 dollars returned to you)
Text me @ 269 266 607six if I can be of assistance.
john
john
- flywheel 2.jpg (535.46 KiB) Viewed 40486 times
jedidan45
Pulling this one up from the graveyard!!!
I read this entire thread and loved every minute of it with several LOLs throughout...David, I saw your post that you had sold the bike several years ago...any idea how much you ended up getting for her???
Super cool resurrection of that old girl!!
