Stem bearing race install
Tyl3r
Post by Tyl3r »
Cant get my bearing races to seat all the way down in the frame :vom: The last bike I did this on, I was able to get the race tapped down all the way in with just a hammer and a socket... this one is a little more stubborn and there isn't much of a lip for me to set the socket on to tap it in. Anyone have any suggestions or tricks?
I would like to take a piece of 1/2" all-thread and put nuts and washers on either end and clamp the race into place... but I feel like its going to be a pain trying to find a washer that's exactly the size I need to set on top of the race during clamping... any suggestions there? I was thinking about just flipping my old race upside down, setting it on top of the new race that is in the frame, then clamping it all up real tight to seat the race. I figure the old race will be pressed into the stem a little bit too, but shouldn't be that hard to pop back out.
Has thanked: 103 times
Been thanked: 26 times
Re: Stem bearing race install
Is it the stock paint job?
Depending on how far down into the frame the old race would go, using the old race may be the ticket for you.
The all-thread and washer stacks is similar to the OEM tools. They are like an old top hat of sorts.
tirebiter
Post by tirebiter »
What I do is grind off a teeny little bit all around the outside of the old race- just enough so it doesn't stick in the frame, but still has enough contact with the new race to work.
Line it all up, put a piece of wood on top of the old race so that the pressure is distributed evenly, then smack away with a BFH...
If I can't do it, I'm sure someone else can!
ecojbr
Post by ecojbr »
I myself would freeze the race and heat the frame, then use your tool.
04 kx220 hybrid
03 kx 250
05 kdx 200
gsa102
Post by gsa102 »
Yes, use your old races for drivers, but put a bead of weld on the inside of the old race. It will shrink them just enough that they will fall out when you are done driving with them. And use heat and cold to your advantage, but you have to think ahead and work fast.
The weld trick works on all kinds of bearings in blind holes.
96 KDX 200, 09 YZ 250
Tyl3r
Post by Tyl3r »
When i put them in at first, i had the race in the freezer for a day and heated the stem a tiny bit (was nervous with the gas tank being right there)...so i tried using thermodynamics to my advantage lol.
Today I'll try clamping the old race on top and whacking it down. I'll let yinz know how my whacking goes! Thanks for the responses :partyman:
Good luck with it.
zepplin153
Post by zepplin153 »
'98 KDX 200 (KLX300 Forks)
Tyl3r
Post by Tyl3r »
wow... yes that would be exactly what I need! I tried all sorts of things to get that upper outer race seated all the way down... and its just not going to go it seems like. So I figured I would try pressing the lower inner bearing on the stem... froze the stem, heated the tapered roller bearing the oven at 250 for a little while, dropped it down on the shaft, put my spacers on top, gave it one whack and the cage broke off and the roller bearings went everywhere :vom: I was going fast and probably didn't plan good enough. So my new plan....
Get some new Pivot works stem bearings (had all balls, but saw and ad in dirt wheels for Pivot Works saying they offer lifetime replacement on all their bearings, no questions asked? sounds too good to be true, but i'll try it), take out the new outer upper race that I got stuck, clean up the mating surface inside of the frame a little bit better with some sand paper, and start over. Maybe I will try getting that seal driver kit for this time... man does that look sweet.... could sure come in handy!
Can't believe I'm having this much trouble on such an easy job... one of these days I'll get to ride it again!
6 Riders
Post by 6 Riders »
Pretty sure (If I recall correctly) that I had a friend use a press to install the lower bearing on my KDX. It took a lot of force to get it on there.
The OEM tool is just a hammer driven tool and adapter, should not need a press.
zepplin153
Tyl3r,
that kit is very handy. you can flip them around and use them to drive bearings too. and its soooo cheap. that is the set i bought and was the best value. I have changes several sets of what you are doing and that kit makes it super easy. Turns that whole job into just minutes of work. Hell, getting the inner lower race off the stem takes the most time of the whole project for me now. In fact if you have any tips let me know.
good luck! post up when youre done.
-zep
Tyl3r
Post by Tyl3r »
Well, I finally got time to mess with the KDX on Saturday. Got everything all put together with no problems this time! I bought a seal driver set at a tool sale, pretty similar to the one posted above by zeppelin. All the drivers had a 1/2" hole in the middle of them, so I just picked the sizes that fit into the races, put a piece of 1/2" all-thread thru em, and clamped em both in at the same time. Went right in like butter, I had em in the freezer for about an hour before I started too.
For the tapered roller bearing on to the stem, I just had the stem in the freezer about an hour or two, then dropped the room temp bearing down on there, put the old race on top of it (upside down) with a piece of pipe, and whacked her right down with no problems. My problem last time was I put the old race down on top of the bearing right side up... this way it was contacting the outer cage of the bearing when I was whacking on it. If you put it down on there upside down, it only contacts the very inner race of the tapered roller bearing. So yea, I'm happy now.
All that is left to do before I can ride it is change the front tire off of the KDX wheel and put it on the KX wheel. O yea, and I need to get spacers for the front wheels... can't remember if they came with the front wheel and I just lost em, or what. So I guess I'll get me a set of those and might as well put new front wheel bearings in for peace of mind. But who knows when I will get another chance to mess with it! Lol hopefully this weekend. Here is how she's sittin now (I cleaned up my mess after I took the picture, so don't judge my messiness lol) with the KDX wheel and headlight just sitting on there:
zepplin153
Alright man!!!! :supz:
ICRage42
Post by ICRage42 »
Those forks sure do look nice and beefy on there. Grats man
Tyl3r
Post by Tyl3r »
Thanks! Im dying to ride it!! lol hoping to have the new wheel bearings in and front tire switched over this weekend if Im not busy with other projects. Still too snowy to ride with no studs tho :cry:
royadams
Post by royadams »
The easiest way for me to change the lower stem bearing, is to press the stem and bearing out all at once. Then just press the stem back in, then the bearing.
dfeckel
Post by dfeckel »
My trick is to take the old race and use an angle grinder to cut a slot through the race. The cut race looks like the letter c with the ends very close together. This makes it very easy to remove after using as a driver to seat the new race.
David Eckel
