KDX
Malarkey01
KDX
Post by Malarkey01 »
Hi Guys,
De250r
Re: 96 KDX "Blurrpiing"
Post by De250r »
Invest in a manual. Pull carb clean very well and check main jet size. Sounds like its something simple. Don't get discouraged. Tinkering on these is almost half the fun.
Sent from the back woods of vt via patchy Internet
Live free and ride hard
One of our favorite phrases here at KDXRider....new plug, clean filter, clean carb, fresh fuel then jet....no shortcuts. Pick a fuel oil ratio (most go 40:1) and stick with it. Can't even begin to count the number of folks who have started a post like this, refused to follow the process, and months later come back with "I finally rejetted and this bike is awesome". It's not tough, and only takes simple hand tools (as does most of the work on these bikes). Welcome to the family and good luck.
BTW...
de250r wrote:Invest in a manual.
Your bike will love you for it.
Malarkey01
96 KDX "Blurrpiing"
Thanks Guys!
rbates9
Been thanked: 2 times
96 KDX "Blurrpiing"
Post by rbates9 »
Malarkey01 wrote: You mention 40:1. I am using the Bel-Ray H1-R 100% synthetic oil for my premix. The back of the bottle says 50:1. So I have been running 50:1 (only have put in 2 tanks of fuel so far) but according to you it might be better to run 40:1?
Thanks!
The "factory" spec is 32:1. But that was a long time ago. Most modern mix oil is much better then it was in the early 90's so 40:1 has become a more common ratio. 32:1 of 50:1 can both be run with success. The common idea about this topic is the bearings like to have oil so most people tend to go with a 40:1 for piece of mind. The biggest thing is to pick something and jet for it and then stick with it.
zz3gmc
96 KDX "Blurrpiing"
Post by zz3gmc »
Could also be a crank seal. I have a very low hour 96 200 in my garage that needs the crank seals replaced. Wont clear up on top, smokes alot and is losing trans fluid. The bike is 17 year old and the seals tend to harden over time especially with ethanol based fuels.
