Tighter turning
MikNY
Tighter turning
Yes, a Belarus from the late 80's. Great simple machine, rude, crude, and fun to drive. It is very effective at loosening its own bolts and marking it's territory...
- rbates9
Tighter turning
Cost effective equipment. Until something breaks. Then if you can find the part in the first place, cost is not an issue. I have known of several that have found a home in the weeds for small, simple parts that just can't be found.
There is enough around that you would think there should be some sort of parts supply for them.
MikNY
Tighter turning
So far I haven't had any trouble with parts, joined a yahoo group that seems to be able to find anything. I will use it as long as its economically feasable to do so.
- 6 Riders
Re: Tighter turning
I had my forks redone recently....a few tid bits about these USD forks....They are not tunable, no shim stacks etc. Springs are way light, my 200 came with .29 springs in them, I'm a 160# rider and went to .42's. Use 7.5 weight oil and adjust the compression damping by adding/removing oil 5cc at a time.
Lowering the forks in the trees works well, as stated above, but you loose some stability in the high speed stuff.
I had my forks "serviced" with new springs and a "balancing hole" drilled in the damper to help the oil smooth out the ride a bit. Made a huge difference in the ride of the bike and the stability of the front end.
MikNY
Tighter turning
Looking at a set of 92kx250 forks now. The more I read it seems this is how to handle the front end. Now to look into what is required for the swap.
MikNY
Tighter turning
Been reading the fork swap section, seems like most of it is for the 200/220 so not sure if info is the same. Are there any year/model kx forks that will slide right into my 94 kdx 250 triples? Sorry if the is covered here already.
- Has thanked: 10 times
- Been thanked: 17 times
Re: Tighter turning
No, not really. Obviously its the clamping area that matters, and that can even vary on forks of the same size. I would look for a complete front end.
Sent from my HTC6435LVW using Tapatalk 4
MikNY
Tighter turning
Ok thanx, just gonna ride it the way it is for a while then. Really makes ya wonder what they were thinking when they chose this setup for the frontend.
Re: Tighter turning
They were thinking of intermediate riders on slower trail rides, which those forks will soak up quite well if they are in proper condition. :)
Sent from my HTC6435LVW using Tapatalk 2
MikNY
Tighter turning
Last fall I replaced the fork seals and used Motul 5w. I was told the 5w would lessen the harshness and cut down on the deflection in the rocks. Still hoping to get them to deflect less, any tips?
Goofaroo
Re: Tighter turning
As I mentioned earlier, try some 2.5 wt. If that doesn't suit you then your next option is to modify the damping by enlarging the oil passages on the dampener rod. You can find a set-up that works well but it will take some trial and error.
That is some good advice.I had my forks redone recently....a few tid bits about these USD forks....They are not tunable, no shim stacks etc. Springs are way light, my 200 came with .29 springs in them, I'm a 160# rider and went to .42's. Use 7.5 weight oil and adjust the compression damping by adding/removing oil 5cc at a time.
MikNY
Tighter turning
Thank you, he had mentioned 7.5 weight in the above post and I used 5w hoping I was going in the right direction. Seems I need to try 2.5. Thanks for the help, def appreciate it. Like jetting a carb, lots of trial and error till it just "feels" right.
MikNY
Re: Tighter turning
Added a set of "bark buster" type guards. Cut the original plastic guards to fit over the metal ones.
Sent from my C771 using Tapatalk 2
- Has thanked: 153 times
- Been thanked: 38 times
Re: Tighter turning
GREAT looking 1994 KDX250!
1991 - 1995 KX125/KX250/KX500 tubes are the same diameter (and 1996 KX500), as best I remember from measuring various fork tubes I have.
zz3gmc
Tighter turning
A straighter bend bar with less sweep back will get your weight over the front and help in turning. Looks like you have the stock bars on there.
MikNY
Tighter turning
Good point, I rotated the bars forward a bit and it def helps but a different bend would be better. Picked up a front end from a 91 KX250 in decent shape, will get it set up this winter.
The bump stop on my rear shock started coming apart this weekend, can't really complain as its 19yrs old.
MikNY
Tighter turning
Guess I'll be replacing those bars, the new section of single track we cut this weekend was tougher than I thought it would be... Bent 'em up pretty good haha.
MikNY
MikNY
Re: Tighter turning
Took a vid too but the phone camera doesnt seem to capture the motion well.
MikNY
Tighter turning
Ok, heres the vid. It's weak, and blury, and generally sucks but hey I tried. Not nice to make fun of old people...
